  • Replies 14.2k
I knew you sold the 34 for an upgrade, I bet that thing handles a treat! What lap times you getting in that thing? :P
that all depends on what sort of hamburger on a stick he has dangling from the front
and it depends on his tuners preference
like, if sled was in the trolley and it was john keen pushing said trolley, he'd probably want an aussie meat pie attached to that stick
but if it was martin donnon pushing the trolley he'd probably want a triple cheeseburger (martin i know u read this crap, are u a hamburger man or hot dog? or are u into meat pies and if so villis or mrs macs?)
if it was my tuner gil he'd do a 1:05 if it was a steak sandwich with mustard
while i cant tune for shit, if i was pushing the trolley then it'd have to be a vindaloo at the end of that finish line, but with delhi belly you'd be expecting 4-5 minute laps
depends on how tasty the food on that stick is i think. thats my philosophy
if greyhounds can chase rabbit, we can chase burgers
-D
well as you can see, no motor at the moment......Ripz are throwing a 30 together for me as we speak............cause that's how I roll!
i hadn't read the other replys when i replied, but Matty is right. I think the later cheffy's may have had BOV's but the early one definitely didn't.
So your not using the TD? If not when can i pick it up? :P
Edited by D_Stirls
Just finished watching Paranormal Activity, f**k me that's a scary film. Not usually one to get a scare out of those films but this had a few moments for sure!
I just finished watching this movie and I'm going to have to call you a pussy Luke!
I started watching it after midnight, alone in my house with all the lights off and all the windows and doors open and I kept waiting for the scary stuff to start. It didn't. The only thing I got out of it was that the boyfriend was a tosser and [deleted to avoid spoilers].
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
