Anyone know the policy about a factory closure due to warm weather? Like, a law.. that says you have to close it once it gets to a certain temp like back at school?
its negotiated with the employer
http://www.ohsrep.org.au/hazards/workplace.../heat/index.cfm
-D
  • Replies 14.2k
my union at the airport is pathetic, they couldnt talk organise there way out of a paper bag... if it was soggy and easy to tear. hence why they dont get my monies.
we have to work regardless, last year out on the tarmac it was 50degrees, and we had to work in the belly of planes that had been sitting in the sun all day so imagine the temp there... no bonus pay, no leaving early you just work untill you drop
Yeah I remember school left early if it was going to be 38+. Even better in a double bricked, tin and asbestos lined roof. Oh.. and our 200+ degree extruders. Love it.
they did that at my school only thing was you were walking back home during the hottest part of the day. 45min death march for me :P although i didnt mind cause i didnt have to do school work.
Yeah its redicilous at our work. No climate control AT ALL, meanwhile machines running at 200degrees and massive hydro style lights hanging from the roof which are always turned on never off and theres like one every square M..
Fail factory. No A/C in the lunch room either :P
Treated worse then animals...
Edited by Weezy
Yeah, how some of these employers get away with making staff do labour in 40+ weather is beyond me. Sounds like Rhys job is comparable with electricians and cablers, getting stuck in roof cavities in 40+ weather trying to fix someones aircon is pretty damn nasty. I feel for mechanics and other folks who have to work in such conditions... for the most part I'm on the road in my car with the aircon on full, or I'm in an airconditioned office or server room. Sometimes I have to go into the factories and when I do, I feel the heat more than the other blokes there (cause theyre acclimatized)
TBH if I was a labour based employer, I'd be giving the workers the option of working at night time instead (unless of course the factory is already 24 hours/split shift rotation) - even then, it doesnt cost a lot to get a monster of an evaporative cooler in a factory and run it, and those evaps work quite well when the building isnt completely sealed...
-D
They got us 'hired' coolers last years summer right at the end so there was 2 weeks of summer left, what wankers. and before then they gave us spray bottles so we can spray water on our faces? WTF does that do?
Of course the boss' office is climate controlled :(. The extrusion operators are the only people in the whole of PPI that don't have a climate controlled environment, Even the store boys and maintenance man have A/C's in their offices etc our lunch room doesn't even have an A/C... We ask and we get an answer just to stall the situation so its like bashing your head against the concrete floor. FML :P
If employers gave half a f**k about their employees as much as they do profits I'd be a happy man and I'd be more inclined to work my ass off in this heat. But when management will just sit on their ass all day in their a/c offices without a care in the world about my safety I'll be happy to turn my line speed down to 11 metres a minute and take it f**king easy.
Thats right,
PPI gave me the chance to buy the GT-R and they felt they could take it away, so a big coil of pipe was dropped on my front bar. Of course not on purpose... But none-the-less pretty disheartening LOL.
Worktime yo
Thats something that would shit me too
Theyre >sitting< in their offices and doing non manual labour - they got their aircons tho, probably reverse cycle, chewing up 3kw of power per hour
Factory workers, busting their arses in hot weather and they get given a spray bottle? Nigga please
Time for a riot (or to get the union to do their damn job for a change)
-D
years ago I used to do security during the Rio Internationals at Memorial Drive (which is always in the middle of Summer).
Whilst the tennis players could walk away after a certain temperature, we'd have to stay there for the entire day = Big Fail :P
Not sure whether they measured air temp or court temp but at a certain temp they'd throw the tennis racquets down and leave us out in the open.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
