  • Replies 14.2k
Yeah no shit hey. Trying to find out about catch can setups/ oil mods for some piece of mind and just when I get some useful info someone two posts down trashes it.
All I want is a lightly tuned reliable GTR.
  • Oil mods like which catch can, relocator and oil cooler
  • Front pipes (No I'm not going to AM Performance
  • Pods or panel filters
  • clutch, ebc, injectors, cams, fuel pumps.
Too many options, too many chances of buying a brand thats not going to work well.
It's simple, there's ASSLOADS of recommendations out there. Easiest way to pick what works, go to the RB26 dyno thread, compile a part list, work from there. That way you know what works and what doesn't.
As for your list...
[*]Oil mods like which catch can, relocator and oil cooler - JJR Autech catchcans are the trick, simple, cheap, easy
[*]Front pipes (No I'm not going to AM Performance) - If you're not going to listen to heaps of people recommending you see Andrew, I won't answer this, he is cheap, does quality work and his service is second to none
[*]Pods or panel filters - Standard air box is good for 400atw, it also lets a shitload more cold air in through the air guide, do the math
[*]clutch, ebc, injectors, cams, fuel pumps - Clutch; a nice twin is my opinion but that's personal preference. EBC; anything like the Profec B or the Blitz SBC. Injectors; 700cc Sards, straight drop in, easy as (although not needed if keeping standard tubos). Cams; not needed. Fuel pump; I prefer the Nismo for straight drop in but you can get by with an 044 or 040 Bosch
There you have it, a nice, easy, reliable part list.
I pretty much agree with everything that Heslo said.
For an oil cooler get one that sits in the brake ducting rather than in front of the radiator.
As for cost buy from Japan - Nengun, Greenline, Perfect Run, Import Monster or RHD Japan. With the current exchange rate against the greenback check out some USA sites as well and see how they compare.
There is soooo much info on what to do with an RB26 on SAU that you can get lost but you will soon figure out who knows what they're talking about. Most of the oil mods won't happen until you open the engine so start saving for it. Until that time stay off the rev limiter and put an extra litre of oil in for track days or if you intend to do some launches.
:P So Chad, whats it like to drive a 300kw monster on the road
Entertaining! Just make sure you have good tyres, I'm running crap street rubber atm and the hills scare the crap out of me. 3rd gear plus boost = sideways, even 4WD does not help :P
may i ask what rubber? kumho's im guessing? have u ever tried the toyo t1r? if so, how does it compare?
-D
any one had any experience with fitting these?
i want to run it with this
in one of these.........
fuel tank in there atm hasnt been used in 3 years, so i hate to see the shit in the bottom, also
need to replace fuel pump anyways....
from what ive been told craig, you'd need a surge tank with that setup as well
the only fuel cell ive seen that doesnt require that is a polycarbonate model from autosport, which im purchasing for the 31 for circuit
-D
Think of tyre brands most people haven't heard of before, I never buy good street tyres, i just use second hand crap. It makes driving more fun :P
iced cofee?
correct. well played.
sigh, dont get me started on IC atm..... coles have them for $1.44...
so when i did shoppin thurs night, i bought 15 of em
saves me buying one a day at 3 bucks....
in theory, they should have lasted me 15 days right?
wrong, i have one left.
and f*k it ima drink it nao
Hey Craig, Trent replied in that 17C thread you started in the Forced induction section, Seems it's a bit laggier than first thought with full boost (21psi) @ 4800RPM. That makes it as laggy as a TD06SL2-20G which would put you over the 300kw mark. I guess the old tech' compressor wheel isn't as efficient as the new stuff.
Edited by D_Stirls
Yeah i'll take it, i'm planning on buying a stag' next year so i'll either use it on that, or clean it up, put a kit through it and see if i can make some money selling it on NS, here or on Ebay
Edited by D_Stirls
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
