  • Replies 14.2k
no you wont. you wont even do silly, silly things to girls that are gagging for it.
all you have to do is flop it out.
in other news , rear main seal is fine! woot
chucked it up on the hoist at my mates work today and it was the oil drain hose that had a small hole in it , put some gasket sealer on it and its all sweet for now , when i get more cash ill get
a new hose and fit it when i do oil change next :)
Yep, called up asking about is it ok cause i cant find a second hand one and he's like yeah there fine aslong as it has some writing saying its for fuel its fine.
So i might get a Sard one and put a little note on it and away i go.
LOL! i have many parts on the 31 club for sale, most have been sold cheap ha just to get rid
of it, like standard rb20 turbs+ dump for 50 bucks, coz thats how i roll....
i also have the 2,5'' cat back on there for 50 bucks, some doosch just offered me 20 bucks haha
c'mon, fifty is already cheap.. where do some people get the nerve?
welcome to the R31 Lowball Club Craig LOL
Your problem is going to be the FPR. An aftermarket rail isn't going to fit the factory FPR, but if you have an aftermarket FPR then they will crack the shits because you can adjust your AFR's by playing with the fuel pressure.
Edited by D_Stirls
Your problem is going to be the FPR. An aftermarket rail isn't going to fit the factor FPR, but if you have an aftermarket FPR then they will crack the shits because you can adjust your AFR's by playing with the fuel pressure.
My thoughts exactly
God damm, one problem leads to another lol thanks Dale. :)
Also Luke, Rory Thompson can engineer your cf bonnet for roughly $250, as i was speaking to a R34 GTR owner on sunday saying Rory engineered his Z-tune one no problems.
Very interesting Luke, cheers for that, I'll have to call him but it may not be possible. I think it needs an aluminum frame to be engineered but I will call just to see anyways :blush:
FINALLY picked up my new turbo after calling speedlab jeff for nearly 2 weeks...
ended up just going to JPI and givin them the cash, even had to take it off the rb20 myself :happy: (on works time hehe)
Very interesting Luke, cheers for that, I'll have to call him but it may not be possible. I think it needs an aluminum frame to be engineered but I will call just to see anyways :happy:
This one had no alloy frame and was brought from cartoys for $700. Also got his Greddy coilovers done and all his Cusco suspension arms. The coils didnt have to be welded up either.
God damm, one problem leads to another lol thanks Dale. :happy:
Also Luke, the amount of gain you would get out of an aftermarket fuel rail would be nigh on zip for the amount you'd pay for it.
Not to menion that shiny rails draw too much unwarranted attention which is the last thing you'd need.
There are so many other things that your $$$ would better benefit your car, ie. decent delivery and return lines etc.
There are so many other things that your $$ would better benefit your car, ie. decent delivery and return lines etc.
qft
2JZ no shit?
I will have to make a call to Rory and see what the story is. Anyone have his number?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
