  • Replies 14.2k
no you wont. you wont even do silly, silly things to girls that are gagging for it.
all you have to do is flop it out.
in other news , rear main seal is fine! woot
chucked it up on the hoist at my mates work today and it was the oil drain hose that had a small hole in it , put some gasket sealer on it and its all sweet for now , when i get more cash ill get
a new hose and fit it when i do oil change next :)
Yep, called up asking about is it ok cause i cant find a second hand one and he's like yeah there fine aslong as it has some writing saying its for fuel its fine.
So i might get a Sard one and put a little note on it and away i go.
LOL! i have many parts on the 31 club for sale, most have been sold cheap ha just to get rid
of it, like standard rb20 turbs+ dump for 50 bucks, coz thats how i roll....
i also have the 2,5'' cat back on there for 50 bucks, some doosch just offered me 20 bucks haha
c'mon, fifty is already cheap.. where do some people get the nerve?
welcome to the R31 Lowball Club Craig LOL
Your problem is going to be the FPR. An aftermarket rail isn't going to fit the factory FPR, but if you have an aftermarket FPR then they will crack the shits because you can adjust your AFR's by playing with the fuel pressure.
Edited by D_Stirls
Your problem is going to be the FPR. An aftermarket rail isn't going to fit the factor FPR, but if you have an aftermarket FPR then they will crack the shits because you can adjust your AFR's by playing with the fuel pressure.
My thoughts exactly
God damm, one problem leads to another lol thanks Dale. :)
Also Luke, Rory Thompson can engineer your cf bonnet for roughly $250, as i was speaking to a R34 GTR owner on sunday saying Rory engineered his Z-tune one no problems.
Very interesting Luke, cheers for that, I'll have to call him but it may not be possible. I think it needs an aluminum frame to be engineered but I will call just to see anyways :blush:
FINALLY picked up my new turbo after calling speedlab jeff for nearly 2 weeks...
ended up just going to JPI and givin them the cash, even had to take it off the rb20 myself :happy: (on works time hehe)
Very interesting Luke, cheers for that, I'll have to call him but it may not be possible. I think it needs an aluminum frame to be engineered but I will call just to see anyways :happy:
This one had no alloy frame and was brought from cartoys for $700. Also got his Greddy coilovers done and all his Cusco suspension arms. The coils didnt have to be welded up either.
God damm, one problem leads to another lol thanks Dale. :happy:
Also Luke, the amount of gain you would get out of an aftermarket fuel rail would be nigh on zip for the amount you'd pay for it.
Not to menion that shiny rails draw too much unwarranted attention which is the last thing you'd need.
There are so many other things that your $$$ would better benefit your car, ie. decent delivery and return lines etc.
There are so many other things that your $$ would better benefit your car, ie. decent delivery and return lines etc.
qft
2JZ no shit?
I will have to make a call to Rory and see what the story is. Anyone have his number?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
