  • Replies 14.2k
cant see it at work, but im assuming its the group that says something like there are too many skylines and wrx in adelaide.
but then the people go on about how great commos are inside it :) think there's a s load more of those in adelaide
Sigh
Split the coolant hose underneath the inlet manifold this morning. Lost 80% of my coolant, managed to get it to the mechanics in time. Pissed the last litre of coolant out while it was on the hoist. They had to remove the starter motor to get to it. 2x hoses replaced. Thank f**k its not the heater core hoses. And I'd only put new coolant in 3 months ago, genuine nissan too...
-D
before or after mullers rd Ben?
before - only noticed it when i got to work, went inside to get some stuff and came out to see a massive puddle of ethylene glycol baking in the sun - looked at the radiator, had enuff to proceed but had the bottle of distilled water just in case
-D
EDIT - And main north nissan are all out of that particular hose. Dunno if I find one in silicon from anyone in adelaide before Friday either (it'll take till friday for nissan to get the hose from Melb...)
RB24...that is all :)
I don't know how much it would cost...but 2-2.5k should do it, ill scan a article out of HPI #44, where they start building a RB24, and send it too you.
and the rest abe, i reckon 2k would cover the machining
last time i checked the tomei RB24 kit was 6k :)
Yeah no shit hey. Trying to find out about catch can setups/ oil mods for some piece of mind and just when I get some useful info someone two posts down trashes it.
All I want is a lightly tuned reliable GTR.
  • Oil mods like which catch can, relocator and oil cooler
  • Front pipes (No I'm not going to AM Performance
  • Pods or panel filters
  • clutch, ebc, injectors, cams, fuel pumps.
Too many options, too many chances of buying a brand thats not going to work well.
1) those oil mods wont solve the GTR's problems, they help you at the track and changing filter, but as far as stopping them from spinning a bearing, you really need the sump off!! you can actually do the sump mods with the engine in the car, there actually is a way to take the sump off with the engine still in place! and you want to enlarge and baffel it! the other important mod is the restrictor in the head...not that easy to do, you may be able to do it from the bottom with the sump off tho, but expect to pay $$ for this
2) umm.. okay, why? u know whats on there atm? any particular reason you have singled out this part of the exhaust?
3) pods with shroud or box... once again, for a stockish car why would you want to change them?
4)
a) you having problems with the clutch at the moment? untill it start failing why change?
b) anything with a mac valve, they are the best type of electronic presure control!! (profec b spec 1 has it)
c) perhaps were starting to move away from a lightly tuned gtr?? stock turbos? its going to depend on your current plans, remember if were talking stock ecu there is only so big you can go
d) from the fourms "The answer on duration depends on what RPM range you are targetting, be realistic.
If you intend to use 7,000 to 9,500 rpm, something around 272 to 288 degrees would be the go.
For 5,500 to 8,000 rpm, around 260 to 272 and for 4,500 to 7,500 rpm then 248 to 260 is the go.
That's a simplification, but you get the idea. As for lift, once I know the effective rpm range,
I then choose the highest lift I can for that duration. What valve springs you are using will also determine the maximum lift" just note that once you get over 10.25mm lift you need new buckets as well as springs, you may also start to get clearance issues if you go much higher lift. but once again i ask why??
e) obv if your doing injectors u'd do this
perhaps its better for you to list your goals and we can go from there, but there is ALOT you do need to consider (as your finding out) and alot of the time you do one upgrade and you look at thing having to do 3 more for it!
i can see what your thinking... get the car up to a good base to work from there, but it depends on your 'current' end goals, you might not need to do some of this, and you might want to look at other things instead
1 x Hell Yeah
about time that R was out again luke....cant wait to see you at a villis meet with the R mate
cheers guys... but MORE delays!! =\
who quits work the week before they start on my car XD
What sized tire should I run on the GTR for a 9.5" rim? I was thinking maybe a 245/35 KU36 all round
I run 245's on a 8.5 rim at the track, If i was you i'd be going 255's minimum. No need to stretch your tyres on a 9.5inch rim on a GTR.\
I'm pretty sure Sled had 255's on his 9.5's on his GTR.
Edited by DSTROY
+1 GTR's should have no stretched tryes. Flush but no stretch :)
Unless their 10inch+ I think Shane has stretched 255's on RBWARE, looks f#cking porn!
Edited by DSTROY
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
