The ute or the S13 Dan? :)
Yeah it could very well be Ben,
So hard to get even my hand in there to see/feel whats going on. I can't pin point where its coming from.
Hopefully a good friend of mine will help me out.
either that or the hose above the starter motor (which is what went last week for me) both of them are a prick to get to
-D
  • Replies 14.2k
-D
ca's run their coolant return line for the turbo behind the head as well. and then it could also be the HG.
i give it 12 months and we will prob both be looking for RB20's again lol
Group buy on cheap RB20s? :) skids for all.
Got rad flushed for the princely sum of $0, pretty stoked :)
Will be cruisin round my mates house in about an hour to hopefully get the bulk of whats left done. Might even make the prac this weekend :D
orsum......
went to put the manifold and turbs on the 20, went to put in fiest stud and BAM, wouldnt go in coz there
was already a snapped stud in there, thats not all though, counted 2 more in there :)
total of 3 broken studs ffs....
where can i buy new studs? inc new turbo studs?
