Hmmm. Well in the process of my alarm installation we've found my car used to have a boost controller, turbo timer and some sort of temp gauge. Also my standard boost restrictor has been removed.
Now with that removed and a catback exhaust my installer seems to think I'd be running atleast 14psi and he says I'm risking detonation because my timing or something might not be right and that I should hook up a boost gauge to know exactly how much psi I'm running and he can make it so I don't run the risk of detonation.
Is he talking shit or should I be concerned?
I found a turbo timer when I had my alarm installed. Was all hooked up, working... just was tucked under the dash in the footwell. You find crazy shit under there.
I thought without the restrictor, it runs at 12psi?
Mine still has the restrictor, so I have no idea.
  • Replies 14.2k
Man knows his stuff. Boost gauge is invaluable, esp when you simply don't know all the variables (ie condition and internal construction of turbo, afr's with the current tune, etc etc).
I still got a tonne of shit wiring above my drivers side footwell, thats after removing the old security system and turbo timer and replacing it with a decent ADR compliant one. Loads of bad japanese engineering (read: bits of wire twisted together and taped with racing tape) as well as wires leading from my spotlight button to the thermofan (i didnt realize japan got so hot they needed a thermostat override, meh)...
Another job for me to do next time I find a compelling reason to pull my dashboard off
-D
Dion, if u read this. Was just looking at the engine u brought, you do know u have to pay aus customs, quarantine, agent fee's, docking fee's, storage fee's on that engine when it arrives here? roughly another 800-1k on top of the buy it price which streeter has quoted u.
Lol same. kicked mine by accident and saw a blue flash, then the car wouldnt turn off lol.
I lived in Japan for a stint many years ago. On the Kyushu island, mainly in Takanabe, and it got hot there in summer. Weather was almost identical to Adelaide's ... so I wouldn't be surprised.
:bunny:
ouch.... i hope he did realise this, he seemed to think it was a fair cheap engine :bunny:
sooooooo.....
who wants to give me a hand sunday, need to bolt the engine and gearbox in??
got captain thread comin out tomoz morning to get the 3 broken studs out, quoted $110.
ill put the motor in minus turbs as ill need to grab new gaskets/studs etc and wont have time before sunday....
theres Beer in it for ya.......
please.......
BJ inc
sooooooo.....
please.......
BJ inc
sheeeet, just remembered i hadnt grabbed them engine mounts yet.
tell ya what, i'll grab em tomorrow and either send them your way with one of the boys, or sat nite im heading to redwood park so can drop them off to ya
i just bought a grands worth of shockies for my race car from the states and didnt have too pay any extra tax on them customs had opened the boxes and re taped them shut
I've had quite a few items sent over from overseas worth more than $1K+ and have never had to pay tax on it, yet I have heard of so many that have had to.
Anyone here know spark plugs?
What are these telling me about how my cars running?
Also some new clamps :bunny:
The ends seem to be the right colour, so it tells you it is running right. If you saw plugs that i took out of my car a few weeks ago you would have seen it was running wrong, which now reminds me i need to check the condition of the new plugs.
haha no worries mate.
yeah im planning on dropping the motor in on sunday, as Dale's bro in law needs the crane back, for
a long time by the sounds of it, poor bugger...
yeah if you cant grab them let me know, as ill be down south tomorrow and could possibly grab them??
i got an idea, how bout you bring them to me sunday and give me a hand?? :bunny:
yer mitch, ill be there.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
