Hmmm. Well in the process of my alarm installation we've found my car used to have a boost controller, turbo timer and some sort of temp gauge. Also my standard boost restrictor has been removed.
Now with that removed and a catback exhaust my installer seems to think I'd be running atleast 14psi and he says I'm risking detonation because my timing or something might not be right and that I should hook up a boost gauge to know exactly how much psi I'm running and he can make it so I don't run the risk of detonation.
Is he talking shit or should I be concerned?
I found a turbo timer when I had my alarm installed. Was all hooked up, working... just was tucked under the dash in the footwell. You find crazy shit under there.
I thought without the restrictor, it runs at 12psi?
Mine still has the restrictor, so I have no idea.
  • Replies 14.2k
Man knows his stuff. Boost gauge is invaluable, esp when you simply don't know all the variables (ie condition and internal construction of turbo, afr's with the current tune, etc etc).
I still got a tonne of shit wiring above my drivers side footwell, thats after removing the old security system and turbo timer and replacing it with a decent ADR compliant one. Loads of bad japanese engineering (read: bits of wire twisted together and taped with racing tape) as well as wires leading from my spotlight button to the thermofan (i didnt realize japan got so hot they needed a thermostat override, meh)...
Another job for me to do next time I find a compelling reason to pull my dashboard off
-D
Dion, if u read this. Was just looking at the engine u brought, you do know u have to pay aus customs, quarantine, agent fee's, docking fee's, storage fee's on that engine when it arrives here? roughly another 800-1k on top of the buy it price which streeter has quoted u.
Lol same. kicked mine by accident and saw a blue flash, then the car wouldnt turn off lol.
I lived in Japan for a stint many years ago. On the Kyushu island, mainly in Takanabe, and it got hot there in summer. Weather was almost identical to Adelaide's ... so I wouldn't be surprised.
:bunny:
ouch.... i hope he did realise this, he seemed to think it was a fair cheap engine :bunny:
sooooooo.....
who wants to give me a hand sunday, need to bolt the engine and gearbox in??
got captain thread comin out tomoz morning to get the 3 broken studs out, quoted $110.
ill put the motor in minus turbs as ill need to grab new gaskets/studs etc and wont have time before sunday....
theres Beer in it for ya.......
please.......
BJ inc
sooooooo.....
please.......
BJ inc
sheeeet, just remembered i hadnt grabbed them engine mounts yet.
tell ya what, i'll grab em tomorrow and either send them your way with one of the boys, or sat nite im heading to redwood park so can drop them off to ya
i just bought a grands worth of shockies for my race car from the states and didnt have too pay any extra tax on them customs had opened the boxes and re taped them shut
I've had quite a few items sent over from overseas worth more than $1K+ and have never had to pay tax on it, yet I have heard of so many that have had to.
Anyone here know spark plugs?
What are these telling me about how my cars running?
Also some new clamps :bunny:
The ends seem to be the right colour, so it tells you it is running right. If you saw plugs that i took out of my car a few weeks ago you would have seen it was running wrong, which now reminds me i need to check the condition of the new plugs.
haha no worries mate.
yeah im planning on dropping the motor in on sunday, as Dale's bro in law needs the crane back, for
a long time by the sounds of it, poor bugger...
yeah if you cant grab them let me know, as ill be down south tomorrow and could possibly grab them??
i got an idea, how bout you bring them to me sunday and give me a hand?? :bunny:
yer mitch, ill be there.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
