Dion, if u read this. Was just looking at the engine u brought, you do know u have to pay aus customs, quarantine, agent fee's, docking fee's, storage fee's on that engine when it arrives here? roughly another 800-1k on top of the buy it price which streeter has quoted u.
ouch.... i hope he did realise this, he seemed to think it was a fair cheap engine :)
Yeah, I did know this, and Im still in front of buying locally because I'm not just getting an engine..
  • Replies 14.2k
Hmmm. Well in the process of my alarm installation we've found my car used to have a boost controller, turbo timer and some sort of temp gauge. Also my standard boost restrictor has been removed.
Now with that removed and a catback exhaust my installer seems to think I'd be running atleast 14psi and he says I'm risking detonation because my timing or something might not be right and that I should hook up a boost gauge to know exactly how much psi I'm running and he can make it so I don't run the risk of detonation.
Is he talking shit or should I be concerned?
Well I took the R out for a drive after work. No detonation what so ever and on the STD boost gauge it makes it all the way up to the second to last line. So I don't think that is 14psi. I think I still might chuck it on the dyno just to check my AFR settings.
I want a boost gauge.. But where the standard GTR cluster is. Anyone know of any? Or where others have mounted their boost gauges?
nismo 1 looks the goods but it reads boost in kg/cm2
http://www.nengun.com/nismo/console-meter-skyline-r32-gtr
Edited by J-Dawg
I had the original aftermarket boost gauge bolted to the left hand side of the dash cluster which was not very regency friendly, and dog ugly.
Mounted this one and an oil pressure gauge where the clock used to be.
-D
I want to try to keep it as STD or original as possible. Might try and get one of those Nismo clusters.. Don't really see much else out there
Edit: Yeh Dave.. Exactly what I'm looking for! How much that set you back? PM if need be.
Edited by J-Dawg
Yeah I hate that too Dan. No point having two boost gauges! Just replace the standard with one that runs at PSI or BAR and is more accurate
Easier said than done, all 3 gauges in the centre are electronic based gauges which use the same circuitboard. It could be possible to replace the fascia with a psi or bar version however I've never seen one available for purchase. Most of the time people replace that 3 gauge cluster with either defi electric gauge 3 pack or 3x 52mm individual mechanical gauges
-D
Ive got this sort of thing:
http://cgi.ebay.com.au/RADIO-SLOT-POD-3-x-...=item19b78f0f2d
using oil pressure guage, my aem wideband ratio guage, boost guage
not installed yet, then will sell my apexi boost guage
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
