  • Replies 14.2k
^^^LOL Craig.......you can be a funny bugger sometimes :D
Kietz, we're all in suspense..........why the change of heart all of a sudden?
Didn't the 34 bits bolt on the way you may have anticipated?
well i took my car through i.d check they were all cool with it all needed was change was the bonnet and tint removed, i did all that chucked a standard r34 gtr bonnet on and removed the tint went back and then they said i need to change the whole front end back to the original... such a big headache! so now i gta change the whole front back to r32.. got all the parts now, just have to fit.. once its done the r34 gtr will be back on with a fresh respray and r34 neo engine =] definately be seeing me on the cruises to come!
he came from the shallow end of the gene pool,,,, what a moron
DING DING !!!We have the winner for the biggest idiot in world
and Damo are you that bored your surfing every forum ????
nah i dunno about that one, my mate (mechanic, known by a few as a real good skyline mechanic) worked for a dealership once, he said a lady cleaned out her engine with detergent and a hose because when she dropped the oil it was dirty :D
ilold
a few happy snaps from last night, new lens for my camera,, these were handheld not tripod and from backyard , maybe try it with tripod next and black specks would be lens dust from trees wind or aliens...lol cant be stuffed fixing them , clean the lens instead...lol
1300mm lens and 2600mm lens shots and highly compressed photos to post on the web... hi res looks sweet
just for your Entertainment today,,,,lol
ilold
thats the outside of the motor though
n call me obsessed but the faint white lines starting from the top right on the moon there remind me of a basketball :D
Edited by Inline 6
looked more like a moldy grapefruit...lol
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
