hrm that looks good with white. methinks they'd look nice on my r32 >:)
-D
Well I'll have a set coming next week. So you can see what they look like. But I don't think you want the sizes I'm getting.. Bit too 'illegal' for your liking.
  • Replies 14.2k
yeah i think i'd be after 18x9 at most (34 gtr rim size) or the 8.5's.... but will be nice to see regardless
-D
much hope the 31 sounds like this when finished with side pipe
no craig, you want yours to sound like this
or this on idle
btw, my side pipe will be similar design and hopefully pop flames like such too
ok i just cant not post this, i know ill make a few of you blow your load.
http://speedhunters.com/archive/2009/12/08...31-skyline.aspx
fanki's car
lowest 31 in australia. loves munching front guards too
Edited by Matty 31
/chop images of pron 31
sounds O-K.....
thats how decs is gonna make my cooler piping, looks like shite, but atleast its much shorter...
Kye, can you link my aquarium to NS.com for me dude?
cheers
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
just did it craig
http://www.nissansilvia.com/forums/index.p...howtopic=419835
Does anyone know if regency will accept R32 GTR front brakes instead of R33 GTST front brakes when registering a 25'd 32?
Here is the part about that in my letter: 10. That Nissan R33 296mm X 30mm disc brakes and calipers are fitted to the front axle.
If I have to use them its fine, but my understanding is that brake wise R32 GTR > R33 GTST. Maybe I should give them a call and ask..
I think r32 gtr non-brembo brakes are the same as as r33 gtst brakes anyways
ugh. went to the dr's about my sleeping and anxiety issues, instead of finding a solution, "heres some drugs, enjoy." f**kin.
anyone got suggestions on what torque to do a hubcentric bolt on spacer up to ?
110nm + some loctite.
asking for a little help
posted in borrow section too..
me 'na mate are rebuilding a suzuki f5a 543cc 3cyl hatch atm, engine is out on ground
cant get the flywheel off, etc.
need to borrow a flywheel stopper holder lock tool
anyone?
anyone?
rattle gun works a treat ;D
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
