  • Replies 14.2k
just watchin that vid that matty posted again, and noticed the AFM on the strut tower, not even
connected to the intake... how does that work? me want?
it doesnt. had something to do with the regulations specifying that it had to be connected. didnt say it had to be connected and in use though.
Anyone know of a black R34gtr getting around ?
i used to spot one regularly in town during the day craig, led tail lights and big(ger than stock) rims, and if i remember correctly it had personalised plates
havent seen it for a while though, say around 3 months
ahhh ok, i thought it was so you could run a solid pipe to pod without havin AFM in between....
but upon actually thinking about it, it wouldnt work..
Well i had some what of a sucessful day. got the Cressy i bough a few month ago running (just an ignition issue in the end) but then found that the headgasket is stuffed (which i suspected anyway). So if anyone wants an 1993 MX83 Cressy with 178,000km's on the clock with a blown headgasket you can have it for $1300. Or i'll do the gasket myself and put $3000 on it.
Also started pulling parts off the CA to clean them up;
EDIT!!
As for the R32 GTR Vs' R33 GTS-t Brakes they both have the same diameter but the GTR rotors are thicker (32mm V's the GTS-t's 30mm)
Edited by D_Stirls
argh, ive fiddled too much and now the GTR doesnt run smoothly...
ive posted a thread in forced induction, but still:
ive:
removed all the recirculation piping, and blocked off the inlet pipe holes
moved the boost solenoid to a better place
cleaned the AFMs
and put the stock breather hoses and PCV back on, no longer venting gases to atmosphere.
drove fine (with better power steering mind you!) for about 1km, with small amounts of boost,
but now it barely runs, and is stuttering all the time... any ideas what ive done?
where do i start :blink:
Hmm, have you asked if that was okay to use on the AFM's?
I know when I cleaned out AFMs working at sinergy we used Brakecleaner which is a thin liquid that smells really really strongly you can almost taste it and it drys with no moisture left behind.
It has to be the way you plumbed up all the piping etc
i use the stuff at work all day long to clean electronic components
and if it was the pipingm, why would the car run fine for the first half of the trip?
Could have done something and made it over fuel, and now your spark plugs are fvcked hence why it took some time.
Maybe take out your spark plugs and have a look man otherwise I got nfi lol.
Bed time, will check this tomorrow though good luck :).
Bed time, will check this tomorrow though good luck :) .
does anyone know if altering the length of the inlet piping after the AFM will alter the way the car runs? or should the tune pick this up and self-correct??
I know someone who has a R34 Vspec 2 in black ???,, she lives in north adelaide area, dark hair , has a built forged motor in it.
actually she looks a lot like that chick damo...lol, only a model not athlete..lol
asking for a little help
posted in borrow section too..
me 'na mate are rebuilding a suzuki f5a 543cc 3cyl hatch atm, engine is out on ground
cant get the flywheel off, etc.
need to borrow a flywheel stopper holder lock tool
anyone?
a screw driver run thru one of the balance holes is usually enough, if not try a steel scrap through the starter hole ..
if you can get one bolt off, use a steel flat bar and make one,, drill a hole in the end , pop the bolt back into it and use a bellhousing bolt for the other end.. works a treat. WD40 helps too..lol
some take a light heat from a heat gun or plumbers torch to get loose.. but dont overheat the rear main seal or it will melt.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
