  • Replies 14.2k
just watchin that vid that matty posted again, and noticed the AFM on the strut tower, not even
connected to the intake... how does that work? me want?
it doesnt. had something to do with the regulations specifying that it had to be connected. didnt say it had to be connected and in use though.
Anyone know of a black R34gtr getting around ?
i used to spot one regularly in town during the day craig, led tail lights and big(ger than stock) rims, and if i remember correctly it had personalised plates
havent seen it for a while though, say around 3 months
ahhh ok, i thought it was so you could run a solid pipe to pod without havin AFM in between....
but upon actually thinking about it, it wouldnt work..
Well i had some what of a sucessful day. got the Cressy i bough a few month ago running (just an ignition issue in the end) but then found that the headgasket is stuffed (which i suspected anyway). So if anyone wants an 1993 MX83 Cressy with 178,000km's on the clock with a blown headgasket you can have it for $1300. Or i'll do the gasket myself and put $3000 on it.
Also started pulling parts off the CA to clean them up;
EDIT!!
As for the R32 GTR Vs' R33 GTS-t Brakes they both have the same diameter but the GTR rotors are thicker (32mm V's the GTS-t's 30mm)
Edited by D_Stirls
argh, ive fiddled too much and now the GTR doesnt run smoothly...
ive posted a thread in forced induction, but still:
ive:
removed all the recirculation piping, and blocked off the inlet pipe holes
moved the boost solenoid to a better place
cleaned the AFMs
and put the stock breather hoses and PCV back on, no longer venting gases to atmosphere.
drove fine (with better power steering mind you!) for about 1km, with small amounts of boost,
but now it barely runs, and is stuttering all the time... any ideas what ive done?
where do i start :blink:
Hmm, have you asked if that was okay to use on the AFM's?
I know when I cleaned out AFMs working at sinergy we used Brakecleaner which is a thin liquid that smells really really strongly you can almost taste it and it drys with no moisture left behind.
It has to be the way you plumbed up all the piping etc
i use the stuff at work all day long to clean electronic components
and if it was the pipingm, why would the car run fine for the first half of the trip?
Could have done something and made it over fuel, and now your spark plugs are fvcked hence why it took some time.
Maybe take out your spark plugs and have a look man otherwise I got nfi lol.
Bed time, will check this tomorrow though good luck :).
Bed time, will check this tomorrow though good luck :) .
does anyone know if altering the length of the inlet piping after the AFM will alter the way the car runs? or should the tune pick this up and self-correct??
I know someone who has a R34 Vspec 2 in black ???,, she lives in north adelaide area, dark hair , has a built forged motor in it.
actually she looks a lot like that chick damo...lol, only a model not athlete..lol
asking for a little help
posted in borrow section too..
me 'na mate are rebuilding a suzuki f5a 543cc 3cyl hatch atm, engine is out on ground
cant get the flywheel off, etc.
need to borrow a flywheel stopper holder lock tool
anyone?
a screw driver run thru one of the balance holes is usually enough, if not try a steel scrap through the starter hole ..
if you can get one bolt off, use a steel flat bar and make one,, drill a hole in the end , pop the bolt back into it and use a bellhousing bolt for the other end.. works a treat. WD40 helps too..lol
some take a light heat from a heat gun or plumbers torch to get loose.. but dont overheat the rear main seal or it will melt.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
