  • Replies 14.2k
my glove box won't open, anyone got any ideas how to open it without smashing the lock???
when u put the key in it will lock and unlock but when u pull the lever it won't open
the lock it self seems very loose when i have the key in and clicks when u turn the key
any ideas...............
unscrew the hinges from the bottom of the glovebox. once theyre off you'll be able to unlatch it from the striker
-D
All this talk about the new applebar.
Must say it does look the goods.
Not too many places playing decent house/tech/prog etc. Fumo has some good tunes sometimes. Not loud tho. Sugar used to play decent tunes. half the DJs are on smack playing now tho.
Will deff check it out one night for sure.
anyone know where i can pick up a silo diff?
also i cant seem to find the general parts section on r31club!?
cheers
not sure, but if you ever need one rebuilt or converted, speak to graham at boss engineering @ lonsdale
dude did a wild 4:11 LSD for my old 31 that was unblvbly good.... wasnt cheap as I did a total rebuild but im sure he could custom make something based upon the stock diff housing that'd suit your budget
-D
cheers
You need to be a member on the 31 club, and have a minimum of say...5 or so posts.
Remember, any price that is posted, you can demand for a fraction of that price and get them to deliver for free :laugh:
Ill have a quick 'skwiz' for you, and link you to anything that comes up. Assuming that you want it from South Aus?
sick.. i will pay $200-$300 ish pending condition..
and adel would be awsome!
cheers
got msn?
[email protected]
Yeah he has, took Lukey for a spin in the R with scandy a few weeks back. We'll convert him :)
Got a bit of work to do :laugh:
RBs need more torque.
Also......need money to get a skyline. Something with a 30DET would be nice...if i could afford it.
Edited by P1RATE
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
