fk i hate this forum sometimes,
some wanker in Melbourne wanted to buy my spare shell i have, it was all going sweet organized a time for the car to be picked up and transported to his in Melbourne , message him now and i get "already got a shell cheers mate"
like FFS you know that i was organizing this one for you but you go buy another and neglect to fking tell me ?
fking wankerrrrrrrrrrrr!!!!
/end rant
  • Replies 14.2k
f^%$! what a prick. sorry to hear mitch. hope you gave him a proper piece of your mind, thats a real arsehole thing to do. Especially going out of your way to organise transport at this time of the year.
Not to make it sound as if you're at fault, you were just organising an honest trade/transaction. but dont organise shit for anyone interstate until you see the funds in your pockets man.
i know , ive got the pricks address, should tell my cousin to go have a word to him
i know i should of gotten the cash but still a flamin mongrel act none the less , im just gonna hack it up and keep the rear quater for my car and rip all the wiring it out and sell it for scrap ,
need my driveway back already
on the bright side; spare bodywork is always good if you are planning to slide mate!
hey btw, I told Stef to have a chat to you, you may have some items that he's after - he's planning a DET conversion very soon.
yeah thats it
yeah he was talkin to me the other night , wants me to wire his new engine when he gets it or somethin along them lines
ahhh very nice for around 6 k that would be a very nice pick up!
haha skrew u chad! if i put the radiator back in it runs... but only just :D hahah merry christmas
yeah doin alright appart from working my ass off. unloaded a 6 tonne container of chairs today with the HEAT! im an animal hahaha.. finished paving the backyard aswell so i should have the 26 out mid jan if all goes to plan :woot:
how about yaself mate?
haha skrew u chad! if i put the radiator back in it runs... but only just :woot: hahah merry christmas
yeah doin alright appart from working my ass off. unloaded a 6 tonne container of chairs today with the HEAT! im an animal hahaha.. finished paving the backyard aswell so i should have the 26 out mid jan if all goes to plan :ermm:
Yeah things are going pretty well, picked up a cheap ceffy do do some skids in. I've only had it a few weeks and the back tyres are already down to the steel belts :D
lol ur a nissan rb pimp hahah! 3 rb powered nissans infact i think you beginning to be selfish :woot: haha better to do skids in that than the 32 :ermm:
ugh. long motherf**kin day. finished work at 3am. started drinking at 6, got home at 1, spent 9 hours being all entertainer spec while enjoying the great pool weather.
dead f**king tired now. need sleep. so that i can get another early start with the drinking tomorrow.
Hey Dale, do you have any other 4 stud rims laying around apart from the ones in your sig?
I just sent you a email on face book, it just so happens i do.
17x7 GT-P copies (My 180 runs genuine GT-P's) they'll come with rubber as well.
Edited by D_Stirls
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
