  • Replies 14.2k
sweeet congrats man! looks like were both goin through similar motions atm :blush:
Time for car update :)
After getting stuck on a dirt rd in Ashton and then towed to adelaide/loby rd and then towed to the workshop i decided to see how my clutch looked.
I actually manage to get the gearbox and clutch out all by myself :D
After that i decided that since im on holidays till monday i might start taking the motor out.
post-38653-1262690934_thumb.jpg post-38653-1262691009_thumb.jpg post-38653-1262691052_thumb.jpg post-38653-1262691089_thumb.jpg
I manage to do all that by myself from sunday to today :D
Hey Jenkies how are u mate?
Just letting u know if u dont already, but my engine was getting stuck on the front diff shaft, what u need to do is open the front diff housing, in the middle there a 4 splines which rotate around, u need to put a lever bar in there and a slight tap will pop the shaft out.
This got me stuck for a good 3hrs.
Well on the subject of f@cked things i think the turbo on my ceffy has just eaten a huge wang! I went to spin second and just as i let the clutch out the car just lost power. Now the thing wont make any boost, Boost guage only goes to 0 no higher. think i snapped a shaft or lost a wheel :blush:
Good thing you're looking at a new turbo :)
good mate working hard during the day to pay for my working hard at night hahahah. second night so far but after 9 days straight at work which im half way through i hve 5 days off where i indend to get the motor completely out on first day then get cracking on everything else. im sure ill be calling ya when i get stuch with any thing ! props for doin it all yaself man! crush any fingers?
spewin mate! fingers crossed for ya but it sounds rooted! cheers heaps for dropping by work today. was great to see ur beautiful stag and have a chat. broke the day up nicely for me! sounded wseet when ya left aswell.
No probs man :blush: I thought you would like the RB love :)
Sure it's not just a cooler pipe?
I've had a cooler pipe come off before and i could only drive at walking speed. I drove the car home like normal, it rev'd to 4000rpm no prob, just takes ages to get there. It was blowing some smoke higher in the revs so I'll have a good look at it 2moro and see if anything has come off.
my cars going fine......that is all.
i feel uncool now someone lend me a spanner i need to rip out my motor so i can be 1 of the cool kids too :D
you have a night kids sticker and your uncool?? =P
and im fairly sure having ur engine out makes u broke, not cool XD
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
