  • Replies 14.2k
I've had a cooler pipe come off before and i could only drive at walking speed. I drove the car home like normal, it rev'd to 4000rpm no prob, just takes ages to get there. It was blowing some smoke higher in the revs so I'll have a good look at it 2moro and see if anything has come off.
can still be a leaking hose
Hey Jenkies how are u mate?
Just letting u know if u dont already, but my engine was getting stuck on the front diff shaft, what u need to do is open the front diff housing, in the middle there a 4 splines which rotate around, u need to put a lever bar in there and a slight tap will pop the shaft out.
This got me stuck for a good 3hrs.
Hey Luke (and Jenkies)
You don't need to remove the front diff housing - with a couple of lever bars / big flat head screwdrivers you can pop the shaft out in no time at all........saying that well done for succeeding anyway!! Never give up I say!
Cheers,
Andrew
I don't think that the turbo is dead chad. If it was dead it would be showing Vac all the time and wouldn't get to 0 as it's actually producing boost to get to 0.
Took it for a drive just before and it was blowing white smoke like a train.
RB20's are tough little luggers, mine has between 80 and 92PSI on ALL 6, and it has oil in the water, but it still pulled quite a decent figure a couple of weeks ago..
and it blows smoke too..
and I found out my RB25 is still probably a month away :D the place in Japan (not Streeter, the original seller) forgot to tell anyone that thier forklift broke :P
i do, loving every second, we might actually pull off a win
Aussie's will most likely loose this test match and damn right they should....a poor first innings performance by them see Pakistan in a easy position to take a win...currently 3/65 and only needing 176, which i think that they will comfortable get....
will make an exciting third test :(
for Chad
RB25 series 2 turbo, Inspector done by JIS and havent put in the car yet. Fit straight into RB20DET engine. -$375
Sms only please, 0433353768 (I not get on here often now so sms is the best idea)
SSR SP1 17x9, 17x9.5. Cant remember with the offset, I think the front is +19 and the rear +11. Front tyres had about 70% and rear has about 60%. Its on my cefiro and look tuff. -$2000 neg
Edited by craig R33
for Chad
Way ahead of ya mate, going to pick up that turbo tonight :(
Not that keen to pay $2000 on a set of rims for a drift hack.
Also does anyone have an RB20 that i can have a look at so i can work out where the water lines on the turbo go to? or take some pics? My current turbs has no water lines so i need to find out where to hook some up.
Edited by DSTROY
they all in shape Chad, all you have to do is line them up, its near impossible to get mixed up lol
Thing is i dont have any water lines. I'll have to buy some rb25 ones instead. I have noticed that on the block there in a hard line coming off of the block and one coming from behind the engine and they are joined with rubber hose. im thinking these are the old lines cut and joined?
maybe i can cut the new lines and just join them to the old ones.
Edited by DSTROY
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
