  • Replies 14.2k
I've had a cooler pipe come off before and i could only drive at walking speed. I drove the car home like normal, it rev'd to 4000rpm no prob, just takes ages to get there. It was blowing some smoke higher in the revs so I'll have a good look at it 2moro and see if anything has come off.
can still be a leaking hose
Hey Jenkies how are u mate?
Just letting u know if u dont already, but my engine was getting stuck on the front diff shaft, what u need to do is open the front diff housing, in the middle there a 4 splines which rotate around, u need to put a lever bar in there and a slight tap will pop the shaft out.
This got me stuck for a good 3hrs.
Hey Luke (and Jenkies)
You don't need to remove the front diff housing - with a couple of lever bars / big flat head screwdrivers you can pop the shaft out in no time at all........saying that well done for succeeding anyway!! Never give up I say!
Cheers,
Andrew
I don't think that the turbo is dead chad. If it was dead it would be showing Vac all the time and wouldn't get to 0 as it's actually producing boost to get to 0.
Took it for a drive just before and it was blowing white smoke like a train.
RB20's are tough little luggers, mine has between 80 and 92PSI on ALL 6, and it has oil in the water, but it still pulled quite a decent figure a couple of weeks ago..
and it blows smoke too..
and I found out my RB25 is still probably a month away :D the place in Japan (not Streeter, the original seller) forgot to tell anyone that thier forklift broke :P
i do, loving every second, we might actually pull off a win
Aussie's will most likely loose this test match and damn right they should....a poor first innings performance by them see Pakistan in a easy position to take a win...currently 3/65 and only needing 176, which i think that they will comfortable get....
will make an exciting third test :(
for Chad
RB25 series 2 turbo, Inspector done by JIS and havent put in the car yet. Fit straight into RB20DET engine. -$375
Sms only please, 0433353768 (I not get on here often now so sms is the best idea)
SSR SP1 17x9, 17x9.5. Cant remember with the offset, I think the front is +19 and the rear +11. Front tyres had about 70% and rear has about 60%. Its on my cefiro and look tuff. -$2000 neg
Edited by craig R33
for Chad
Way ahead of ya mate, going to pick up that turbo tonight :(
Not that keen to pay $2000 on a set of rims for a drift hack.
Also does anyone have an RB20 that i can have a look at so i can work out where the water lines on the turbo go to? or take some pics? My current turbs has no water lines so i need to find out where to hook some up.
Edited by DSTROY
they all in shape Chad, all you have to do is line them up, its near impossible to get mixed up lol
Thing is i dont have any water lines. I'll have to buy some rb25 ones instead. I have noticed that on the block there in a hard line coming off of the block and one coming from behind the engine and they are joined with rubber hose. im thinking these are the old lines cut and joined?
maybe i can cut the new lines and just join them to the old ones.
Edited by DSTROY
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
