Aussie's will most likely loose this test match and damn right they should....a poor first innings performance by them see Pakistan in a easy position to take a win...currently 3/65 and only needing 176, which i think that they will comfortable get....
will make an exciting third test :D
:) we win!
  • Replies 14.2k
Indeed! Great bowling and Ricky's a great Captain no matter what the knockers say :)
Your right. i cant believe people say ponting's a shit captain. The same people say Johnson is a crap bowler.
ffs. Ponting was announced the highest winning captain in cricket history.
Johnson has the most wickets around the world with the best bowling avg. :D
johnson IS a crap bowler- being a lefty tho he ends up getting the angle across for plenty of edges from RH batsmen
strays far too short and wide far too often.
needs to watch bruce reid at his finest to see how a proper left arm opening bowler does the job.
ponting is a decent captain no doubt, however if warnie was made captain at the time he'd a) still be playing, and b) aussies wouldnt lose many matches.
best cricketing brain (warne) for a couple of decades IMHO
theory on angle ;
whats the diff between a right handed bowler bowling to a left handed batsman ? there are plenty of left handed batters too.
He does stray a little sometimes. But his figures speak for themselves.
Most wickets and best avg this calendar year. How can you say hes crap ?
Id be more 'scared' facing reid (back in the day) than johnson.
Johnson leaks runs, plus you know you'll get a straight short one (guaranteed) for a hook/pull and a wide one begging to be cut for 4
if we are talking variation than Tait would be the best bowler out (yeh fat chance) simply 'cause he cant string two good balls together
fact is, left handed batsmen face a hell of a lot more deliveries from right handed bowlers, over rh batsmen facing lh bowlers - there arnt all that many left-handed bowers out there.
practice makes perfect.....
RB20's are tough little luggers, mine has between 80 and 92PSI on ALL 6, and it has oil in the water, but it still pulled quite a decent figure a couple of weeks ago..
and it blows smoke too..
LOL my old 20 was the same aye. Blown head gasket, blown water pump and a big arse crack in the exh mani right at the collector and it was still cranking skids right till the end :D
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
