good on ya cara for having a smash! but chille! on a much much much more impotant not how the hell do i get my drivers side front drive shaft out HELP HELP its killing me shaft sorta seperated dunno if i broke it or its meant to seperate.. cant wedge anything in to pop it out!
  • Replies 14.2k
Not quite sure where you're coming from Cara, no one had a go at you :/
+1
I was making one of my usual 2 wheeler (motorcycle) jokes, if thats what set you off.
And for the record I've been involved with the Motorplex Consortium for over 6 months now ... attended the rallies, meetings and discussions to get our drag strip happening ... I drag raced for over 4 years at AIR until it was closed on both 2 and 4 wheels ... and that included 40+ degree heat in full leathers.
:D
Ruby wears more leathers than your average german pornstar >:D
-D
thanks mate! i managed to track down an engine crane from a mates dad aswell!! so were lookin sweet appart from a few tiny things now!
shouldnt you be getting moto storm matty for your off road fix?
on the plus side normsta will get to the see the sun still being summer now. ive done 14hr shifts during winter and only got a glimpse of it at 6.30 in the morn.
Edited by Inline 6
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
