  • Replies 14.2k
yeh i cant say im liking internode atm..
say i can get adsl2+, im 2.7kms from the exchange, i ONLY have my modem connected (no phones) and the modem is a adsl2+ $300 belkin router/modem..
and i get this shit connection.. cmon my vodafone 3g card was better and that was shit!
first day with internode=fail..
I'm gonna go ahead and say it's not a problem with Node and more likely something on your end. Tried calling tech support? They should be able to sort your issues. Oh and when you get the chance, piss off that Belkin, they make nothing but shit. Buy Billion, cheap, functional and awesome
almost ready for sanding. yay
thats really impressive mate! your bloody hard at it arent ya! cheers for ya help ova the fone! got both shafts out and upper bellhousing bolts now just gotta get the top startermotor bolt, fuel lines and oil lines to filter. then ITS ALL COMING OUT BABY. hopefully have it doen by mid arvo... got 5 days off starting tomorrow
Check my build thread for more updates in the projects section :)
off to the paint shop in a couple of weeks, new battery tray bit getting welded in to get rid of the rust. And painted engine bay.
Andrew (blue32) popping down this weekend to help with the engine assemble. (still gotta msg) :D
All happening :laugh:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
