No he wasn't damo and Krishy, he left around 2.30 and I stayed till after 4 :(
gotta love short dresses dancing on the little stages.
I went to Flash Dance once with some guys from work, sitting down in 1 of the booths by the dance floor. Had some random chic dancing on the above level, i lent back on the couch and looked up at what i thought was the ceiling...lets just saw i got an eye full of something else :thumbsup::thumbsup:
  • Replies 14.2k
Ahahahahahaha YES!
About a month ago when I was at Flashies, you know how they ask people to get up on the stage in the main room to dance to some bullshit song? This guy got up, pulled down his pants and started waving his bits around everywhere haha. Security literally tackled him and escorted him out. Hilarious!
Ahahahahahaha YES!
Buahahaha :thumbsup:
most sat nights at HQ there is just testosterone filled fully hectic people trying to pickup any girl in sight
I don't even worry about them cvnts. I just chill in the main room and enjoy the music. Soon as the music starts getting lame I bounce and go else where hahaha
So did anyone see the amber petty interveiw on sunrise this morning?
I hate her with a passion.
I hope she f**king moves back interstate. She can get the f**k out of Adelaide. Stupid f**king mole.
And f**k her SAFM breakfast show. Ratings continue to decline yet they keep her and the other airheads on there.
Useless.
I dare say so, Especially sliding. The gate will spend more time open then shut so it'll constantly be screaming the whole day but all in good fun man.
Is there a drift prac that your pushing to have the car done by or just taking your time before you take it out there sliding?
God I'd love a pure slide car, one day soon I hope :(
I'll sell you mine cheap as dude.
Has heaps of work done to it.
Don't you get a fine for missing it? My mate missed it and got a fine for it... like $300 or something.
I didn't go to mine and was only charged like 70-80bux
Useless.
Yeah I can't stand her either. Always slagging men, and wonders why she's single. Any man with a brain would rather date and break up with a female cop before dating Amber :(
Abe, tried Super Pro bushes? Nolathane's have a mixed reputation, with some cases of them just crumbling after a few months..
Didnt even know Whiteline made bushes..
hot 215s stretched onto the 9s this arvo, never seen it done with compressed air before, quite cool actually.
1 more sleep til 31 goes into G7, should be done by end of month.....nice.
then sell and buy a less gay car, like Kye's S13 :thumbsup:
I haven't tried anywhere yet.
No he wasn't damo and Krishy, he left around 2.30 and I stayed till after 4 :)
Heard you were a little messy last night mate :thumbsup:
Oh and happy birthday for yesterday too! :D
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
