  • Replies 14.2k
Sister grasses up brother for having beer in room, parents ground him for 3 months, he finds her 'list' and posts it on facebook, AND tags everyone on the list....
EDIT - Damo, how do get the images to stay in their full size?
right click, copy image location, then wrap it in img tags
lol why would i want a number of a broad minded person like that for??? standards man :(
i get the feeling you didnt type broad minded person ;)
well ya see i needed a scape goat for my joke and lets face it krishy your an easy target, after all your...............................driving a r33 phew nearly got my self in trouble there
Edited by Inline 6
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
