very droll steve :P
well that was the first time i have had the 32 out of the shed in two months. great to be behind the wheel again.
i did however get tailed by and un-marked car, and was 2 cars behind a marked car. Every time i put my blinker on to turn a corner, the guy in the passenger seat of the un-marked car would get on the radio, then lo and behold the marked car would turn that way before me, this went on for a very long 10 min
i got rid of them by changing my mind at the last minute to turn off brighton road, that got rid of the marked car, then i pulled over to take an imaginary phone call, and the un-marked car drove past. I saw the in marked car do a u turn up the road, i took that opportunity to duck down a side street, and hurried home in a law abiding manner.....
i think i'll leave the 32 in the shed for another couple months lol
  • Replies 14.2k
Late model 93' means I got pretty much a 33 GTR motor and my colour matches. I'm not sure what all the bottom shit means though.
Spot on mate, wasn't aware you had a late 93'er....
Still want me to get a price on all those parts for you?
Can anyone tell me where the Vehicle Compuond place is in Ottoway?
A friend on mine has her wrx impounded there, and doesnt know the address.
Claims that she cant find the address on the net either?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
