very droll steve :P
well that was the first time i have had the 32 out of the shed in two months. great to be behind the wheel again.
i did however get tailed by and un-marked car, and was 2 cars behind a marked car. Every time i put my blinker on to turn a corner, the guy in the passenger seat of the un-marked car would get on the radio, then lo and behold the marked car would turn that way before me, this went on for a very long 10 min
i got rid of them by changing my mind at the last minute to turn off brighton road, that got rid of the marked car, then i pulled over to take an imaginary phone call, and the un-marked car drove past. I saw the in marked car do a u turn up the road, i took that opportunity to duck down a side street, and hurried home in a law abiding manner.....
i think i'll leave the 32 in the shed for another couple months lol
  • Replies 14.2k
Late model 93' means I got pretty much a 33 GTR motor and my colour matches. I'm not sure what all the bottom shit means though.
Spot on mate, wasn't aware you had a late 93'er....
Still want me to get a price on all those parts for you?
Can anyone tell me where the Vehicle Compuond place is in Ottoway?
A friend on mine has her wrx impounded there, and doesnt know the address.
Claims that she cant find the address on the net either?
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
