  • Replies 14.2k
damn those wheels look nice J Dawg....whats the specs on those wheels bro
18x9.5 +12 wrapped in 245/40/18
I was with him today when they were fitted and it looks very staunch from behind,
Love it :)
About coolers, Im in two minds about them.
The GT-R one standard is black... So I'll leave it like that and I am getting the front bar mesh so I'll be putting that on,
But if it were a custom system I'd have it all chromed up as it comes out the box :huh:.
Edited by Weezy
He can't even do up a sump plug bolt without stripping the bolt and your going to let him do your cooler install :\ Your game!
I joke :)
Edited by Weezy
Anyone think it's worth painting a FMIC matt black to maintain a stealth look?
I painted mine black to hide the stone dents... some people on other forums have suggested that painting the fmic black helps with heat exchange due to the color black being a heat absorber rather than a reflector like white but tbh I cant see how it makes any difference - esp since putting paint on acts as an insulator.... either way I did it for cosmetic reasons and it does look a lot better imho
on another note
http://thingsboganslike.wordpress.com/2010...-cross-tattoos/
I lold
-D
Edit - It just keeps getting better ;
http://thingsboganslike.wordpress.com/2009/11/18/28-holdens/
http://thingsboganslike.wordpress.com/2009...eir-kids-names/
finally getting a fmic are we steve? :P
Already got it mate, just haven't put in on either. :)
on another note
I lold
-D
+1... I :huh: too
I think the FMIC's look better now black too. Not into the wank wank bling bling look at me look at me factor.
Ben, I also caught 4 squid this morning down at Brighton Jetty. Probably could've got more if I had some more lead
How come u needed lead? Usually they congregate under the jetties...
Didnt get anything last time I went to Ardrossan (nothing legal or edible that is)... blue swimmers are very small this year for some reason
-D
-D
It was quite blowy this morning at 6am so I was having trouble getting the squid lure to sink deep enough. Most of the bluey's I've seen locally are small too as are the tommies
-D
Ended up getting 23 good size panny's ranging from 40-55 cm in whyalla, bugger all bluey's around tho
Just dropped my subframe out the front and all steering lines.
Now for that to get sand blastered next week along with engine assembled :(
painting tomorrow woohoo.
at this rate your car will be finished before mine.... *grumbles* still not f**ken tuned =(
edit: ohhh... caprica startes today, but i think its just re-airing the pilot
When u got the right tools, some know how and some mates who know how to help out it really does help.
Got Andrew coming down Monday to start with the engine. Hopefully I got everything now.
Next is some nismo parts to freashen up the front end. So hopefully in 2-3weeks it will be all running.
been out fishing four times on various nights/various locations this week, holidays ftw!
we cleaned up a good amount of size and some absolute cracker size blueys off grange jetty late Thursday night / Friday morning. We did throw back a shitload of small ones however. picked up a few big sand crabs too.
Every time we pulled the nets up, never empty. More crabs than an 80s hooker's bush. After 1am we were the only ones on the Jetty, and that's when we bagged most, and the biggest.
it was dodge tide that morning apparently, so we didn't try for fish or squid.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
