  • Replies 14.2k
Ive got a r32 wing to get rid of. 30bux in silver
Rubes - got the actuator ready for you. need to test the larger 18pound unit a bit later
will get it to you next week then.
ordered my 235/45 khumo ku36 tyres
also qfm a1rm 780degree track pads
sorted out front and rear braces, awaiting a seat rail for my seat.
also awaiting 4l surge tank & 305lph external fuel pump. comes with 5m braided fuel line
a cheap chip remap is on its way to me so I'll be piggybacking around the tune until I sort my shite out
trying to sort out the injectors, then will be ready to service and do all fluids.
in will go the roll cage to some extent, do a tune and she'll be ready.
sore-as atm, lol
$15 remap chip, lol
9000rpm, speed cut, boost cut, mapping
lol go ebay, like the $1.25 certified roll cage, $100 yellowjacket coilpacks, etc,
with my mapecu piggyback she should be good.
if not, meh. thought Id try tho.
wiring is all done, was lots and lots of spaghettio's of nothingness
found 2 on/off switches, about 10m of wires connected to nothing
everything is out tho, ready for the cage to go in.
No worries mate. I'm flying out to Sydney on Wednesday, not back until Sunday evening. No rush! :)
Then I got the actuator to fit, new intercooler piping to fit, A custom centre console to finish, and a turbo/boost leak to sort out all in one hit! :)
$15 remap chip, lol
does this mean your not going to buy my power fc??? =\
Does anyone here know of anyone or a place that i looking for night time workers?
Or even anytime after 4pm?
I'm doing full time studies now to get things moving quicker so I can finally be qualified!
Thanks yo!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
