  • Replies 14.2k
kids isnt that a club sponser there? depends what you buying there, walk away from the neon and tail light section.
i usually get my oil from the autobahns
forgot about that hahaha
some of the things they sell there shouldnt be sold
Man apply at PPI on night work. will be on about $700 per week. Its down at Ottoway
awsome cheers man. How do I apply for them? On the net?
On my iPhone so can't be f**ked looking for ppi atm
heading back to school full time just need a few dollars to keep me alive.
hindley street corner kye, earn those $
also whos gonna be the first to get 1 of these
http://www.cardok.co.uk/index.php
Been there done that. You don't pay me enough.
Well when the 3L gets built and the gtrs's strapped on I'll take it down the quarter.
if we had a drag strip id be taking it down before and after mods to see how much quicker you get. beats comparing kw figures if you ask me :)
wow, ns.com is sooooooo hardcore mang.
make one comment, and they twist it into something utterly stupid.
uughhh, ill just sit back and lol from now on.
and whats even worse, they must scroll right past the 'useful' info in an effort to hurry up and
get to the fast reply box in order to be xena warrior princess of keyboard warriors.
/rant.
Edited by craig R33
i still need... you free in < 2 weeks matty?? not sure of exact day, but ill be on holidays atleast :P
depends mate, depends
my next RDO is 22nd feb. would much prefer it if it wasnt so hot atm though, the poor old patrol is suffering
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
