  • Replies 14.2k
quite possibly :stupid:
nice
sell off all you dont need, grab 2ndhand what you do need, and go for it
my 6700 r32 sedan rb26 has been reduced by around 1200 in parts sales
then added 3500 back into it to get it up to track-standard.
then less 5500 for bike sale. fun project
today i installed the braided front brake lines, front slotted rotors, and qfm a1rm track pads all round
hoping tomorrow my ju-36's arrive
here is the list from my car:
1993 Nissan Skyline GTs-T Rwd 4door grey sedan4 - $6700
RB30 5speed manual rebuilt gearbox with single button clutch
GTR RB26DETT engine with new rebuilt turbos
5Zigen 3" turbo back exhaust
Turbotech manual boost controller - $35
GTR intank fuel pump
Walbro 305LPH external fuel pump - $165
4 litre alloy fuel surge tank with 5m braided fuel lines - $265
550cc Siemens Injectors with new O-rings & seals - $350
Iridium spark plugs 0.75mm gap - $50
Yellow Jacket coil packs - $150
600x400x100mm fmic kit
Drift pod air filters
Oil filter relocation kit - $110
Oil cooler finned cylinder kit - $90
Ryco oil & fuel filter
Castrol Edge 6L oil
Fujimoto oil drain valve - $35
BHP roll cage - $5
Tomei 300kph GTS dash
AEM wideband kit - $250
Autometre boost gauge
Saas gear knob - $30
Saas steering wheel & boss kit - $170
Bride seat rail - $165
Gephardo race seat & 5-point harness - $200
Nismo ecu remap - $30
Map-ECU piggyback to stock ecu - $200
Car alarm - $35
Hood scoops - $25
GTR rear wing - $25
Tein suspension
Greddy strut tower brace & strut boot brace - $100
Nismo front tension rod link set
Slotted front disc rotors
Braided front brake lines - $80
QFM A1RM 780degree track brake pads - $235
17inch RJR Grafic mags
235/45/17 Khumo KU36 semi-slick tyres - $750
anything not listed means it was already on the car
i'll work it out and send u a pm mate
Awesome, gives me time to save up for a clutch etc.
Speaking of Clutches, i have made a choice of 3;
Xtreme Heavy Duty Clutch Kit $800
NPC 10" Heavy Duty Copper Mix Organic Kit $1093.50
ORC 409D-01N Kit $1399
What do people here suggest, or think?
NPC that will rate about 350 rwkw and its a great clutch
should be ceramic though ?? or did you ask for organic
also 10" is a pull type clutch do you have a pull type
I asked for a 95% street, 5% track type of clutch, and i drive an R33 GTST, so my guess is pull type. They say the clutch is good for 300rwkw and retains the factory feel.
i would get a ceramic Abe and just because its a R33 i wouldnt guess its pull most RB25 boxes are push but the GTR's have pull
your's being 1997 might be pull so don't know see if you can get it down to boostworx or another reputable workshop and get them to check it out
ive heard a lot of people praise and bag Jim Berry
they prolly say 300kw because its ceramic when i did the group buys the ceramic push clutches were 350kw and i sold them into 2x R33's this is why i say better check if its push or pull
push is a bit cheaper there push type Ceramic cushioned with 1200kg pressure plate rated for 350kw used to be about $656 << going from memory 2 years ago
see a lot of info in >>This Thread<<
note all links that say click are dead due to there website being upgraded
Abe - Jim Berry: Race Cluth, leave yourself a good hour and give him a call =) worth if for the info alone
Does he have email? I prefer to have things written down so i can reread and refer back to it.
a while ago they invented these things called pens and paper... some people find them useful, apparently jim is one of these people =P
just my hot tip, dont go for a soild centre cluth!!! :P
f**k luke, you can be a smart arsed flamin mongrel sometimes hey?
dont know if its just me, or my general tolerance being a bit lower of late, but that didnt seem to be a necessary comment to make. same as the mystery that you were trying to elude to in the domestic vs import dyno day thread.
grow up man, seriously
/rant
/rant
wtf is your problem?
english too dificult for you to understand??
i told him that jim doesnt use e-mail? how is that unnecessary??
and the mystery in the dyno day thread was a broken dyno!!! i don't exactally want to say "bosstworx dyno is broken, so dont go there"
think the only person here that needs to grow up is you!
/rant
Its not just you!
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
