Really? I've never heard a bad thing about Jim Berry or his clutches. Can you give me some examples? PM if necessary.
na cant be bothered trolling through many threads about clutches, from memory possibly people either not driving it correctly and chewing out flywheels or starting with too thin a fly, or wimps not liking a slightly heavier pedal from standard
Thanks to your R32 I cant bare to turn the key in mine anymore :laugh: hahaha
anyway, did nightshift last night, got bored:
also, spotted this on Wilkinson Road Gawler River on my way home:
caption 'now let that be a lesson to the rest of you'
Naww :ninja:
In other news, I know of one of the guys who died in the bomb blast in Enfield :)
yeah already pointed out, Damo SAU's new hood :ninja:
  • Replies 14.2k
I bought one from a chick in NSW for $450, second hand, only to have my mechanic tell me that it was 100% f**ked. The springs were loose and there were cracks on the pressure plate. I contacted the chick (who is NSW exec) and denied that it was broken and said that it was fine when she removed it from her car (even tho she admitted it was slipping at 350kw).
$450 down the drain from a 'trusted' sau member, I was pretty shitty. I'm considering sending it to Jim to rebuild but cant afford it at this moment.
Not sure if it was the full monty or mini monty, but it has been the single biggest waste of money ever spent via an SAU purchase.
-D
my 1st sau purchase was for a S2 r34 turbo, ended up getting a shitty S1 r33 turbo.
$600 down the drain, seller refused to answer an pm's or phone calls.
grr
since then hasnt been an issue, plus I sell for cheaps so that keeps karma my way
anyone know the EXACT process of gettin sa reg for in interstate car?
go to transport sa and fill out a form and thats about it. they'll issue you with sa plates unless you specify customs
i believe u only need to go to regency if the car is defected interstate or unregistered. if its registered interstate its just a simple paperwork/numberplate swap.
-D
I transferred a QLD Delica over which was registered and not defected, took it to Vehicle Inspections for them to take a look over it(numbers check etc.) and got a form which says its all good been checked over, took that around the corner to Transport SA and filled out the transfer form paid fees rego and got the SA plates....
correct Vu you will need a vehicle inspection but its not @ regency they check matching numbers and tint and no major leaks takes all of 10 mins checking time and back to regency to pay for plates and vis check
Naww :)
In other news, I know of one of the guys who died in the bomb blast in Enfield :laugh:
did he seem to you to be a candidate for the darwin awards?
from the looks of the blast it makes me think one of them mustve lit a ciggie before planting the bomb
lol
Police 2
Scumbags 0
-D
yeah would have to add a clause if you get there and dont like it then you pay him for his time to come and get you and catch a plane back home
and go for a drive back to his house to finalise paper work and see where he lives :):laugh:
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
