  • Replies 14.2k
moar info pls.
does it dip in revs after u back off, idle rough when cold etc ?
Bit hard to explain. It doesn't really change in revs, it just seems to "shake" a bit more at times when it's idling in neutral. No difference id the engine's hot or cold.
I'm going to have it checked out sometime, but I was hoping to get some sort of a diagnosis beforehand.
Then again I've been told that 34s tend to sometimes idle a bit rough by default. Probably also a case of an aging car.
thought id express my inner anger..
shittest situation...
car is unregistered and on double defected
its going to cost $50~ to get a permit , then ive gotta go to a cop shop and get a clearance note , then come up with $200~ for rego , and another god knows how much for regency.
not to mention stock parts.
all unemployed and without a car...
and looking after a parent.
so angry :)
/end rant
just bought a ''new'' car
ended up gettin a 99 VT II calais supercharged 6, pick it up tomorrow night :)
muuuuuuch better than the Vectra, why i ever thought that was a decent car, i do not know!!
meh, not really interested in modding it, the missus and boy will be the primary passengers, as it
sits will be fine, the only thing ill be doing is 30% tint...
in other news, pretty sure i get the 31 back this week aswell! awesomeness.
so angry :)
/end rant
I didnt think you could rego a defect vehicle? Whether you have a clearance or not?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
