  • Replies 14.2k
moar info pls.
does it dip in revs after u back off, idle rough when cold etc ?
Bit hard to explain. It doesn't really change in revs, it just seems to "shake" a bit more at times when it's idling in neutral. No difference id the engine's hot or cold.
I'm going to have it checked out sometime, but I was hoping to get some sort of a diagnosis beforehand.
Then again I've been told that 34s tend to sometimes idle a bit rough by default. Probably also a case of an aging car.
thought id express my inner anger..
shittest situation...
car is unregistered and on double defected
its going to cost $50~ to get a permit , then ive gotta go to a cop shop and get a clearance note , then come up with $200~ for rego , and another god knows how much for regency.
not to mention stock parts.
all unemployed and without a car...
and looking after a parent.
so angry :)
/end rant
just bought a ''new'' car
ended up gettin a 99 VT II calais supercharged 6, pick it up tomorrow night :)
muuuuuuch better than the Vectra, why i ever thought that was a decent car, i do not know!!
meh, not really interested in modding it, the missus and boy will be the primary passengers, as it
sits will be fine, the only thing ill be doing is 30% tint...
in other news, pretty sure i get the 31 back this week aswell! awesomeness.
so angry :)
/end rant
I didnt think you could rego a defect vehicle? Whether you have a clearance or not?
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
