  • Replies 14.2k
what about rego'ing a defected vehicle that didnt even have time to be transfered into the new owners name??
dont know, never had to do that one before.
best to get the old owner, to get the manual rego form filled out, then the new owner can do the leg work to get it off defect and then transfer rego.
to find out if you can transfer rego on a defect car, go to regency rego office next to the VIS as they seem to be more knowledgable then the other rego offices.
in honour of everyones fav ns thread :down:
we need like an official record ruling about thread length and time cause i dont think ive ever seen a thread hit 50 pages that fast before.
Edited by Inline 6
thread posted - 05 February 2010 - 04:38 PM
first post on page 50 - Posted 12 February 2010 - 08:59 PM
and there has been 1544 replies :|
about 15 of those posts have been relevant lol
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
