  • Replies 14.2k
well i just had the worst most blood curdling experience siting down stairs waiting for the folks to get home when i hear the car pull up and wait for a ding dong
when i hear a child scream i thought nothing of it because we have kids over the back who throw tanties from time to time when the amplitude of the screaming doubled and i went to the back door to only realise it was my daughter screaming
when i got to the front door she was running to it screaming daddy daddy holding her fingers i rushed her in to see no blood phew no blood so i took her in praying for little fingies and running the the paracetamol you can never be to care full with kids and electric windows, i also think nan and pop panicked when they heard the screaming and rather than open the sun roof they closed it further, but the toyota camry has a stupid switch mechanism
all is well and daughter is in bed with ice pack in tea towel on fingers
oh sh*t have you gone and checked her fingers again
whoa. http://www.skylinesaustralia.com/forums/Hk...-T-t307108.html
My dad has one Ruby, but its *just* too small for IC piping, so youd have to file away at the tray to make it bigger.
I might have to get my own. BTW trying to find a pic or link of the position others have used for the fmic piping hole under the battery tray. I'm having no luck. Anyone got a pic or link?
When Jenkies and Chad did mine, it was basically a ready, aim, fire type cut :P
When Jenkies and Chad did mine, it was basically a ready, aim, fire type cut :)
I found a pic of where the hole was cut in an R34, so I'll take a punt from that. Off to Bunnings at lunchtime today I guess. :P
pretty much. theres a bit of praying involved, had to extend mine about 3/4 inch because i missed the mark a little... :)
found a pfc... to buy or not to buy...
hahah arent you selling the tractor soon dave???
oh my
quality - purchased an R32 GTR GTS alloy 52mm dual-core race radiator off ebay
$199 delivered, WOW amazing quality work. australian made.
also received 6x 550cc siemens injecotrs ($360 delivered - new), and a $30 5-point race harness
plus a $160 305Liter/per/hour external walbro pump.
awaiting surge tank & 5m braided fuel line now
also waiting on a $15 remap chip
almost got everything for the track car now. awesome
fuel pump: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWNX:IT
radiator: http://cgi.ebay.com.au/52mm-Alloy-aluminum...=item414cfdbe40
injectors: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWNX%3AIT
oh my
So would you recommend the radiator? As i am looking at getting a replacement for the stock radiator before the SAUSA track day.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
