  • Replies 14.2k
i dont want to join them i hate heavy metal its just screaming in to a mic locky could do that
and i feel like rat shit with my cocktail of hayfever and cold lol i just want to watch gran torino and be on sau lol
NPC gave me a rather nice looking quote - 10inch heavy duty copper mix organic - $643.50 inc gst for the kit. $450 inc gst for a revsolution flywheel...Thoughts?
you know my thoughts.......what's the diameter of a factory plate?
I installed a Extreme cushioned button on a mates car not long ago, drives like standard, holds 350 + rwkw, took out a exedy cushioned button that melted! and was bloody heavy under foot too.
Extreme have got there skylines kits well sorted these days, would recommend no problem at all.
My Extreme cushioned button didn't end up to well, but it did have a hard life from me.
now i have this one, but i don't recommend it for to much street driving.
A Nismo Tiwnplate Coppermix, i don't have ~$2k to throw at a clutch, and if my parents found out i spent that much they would freak....they will most likely freak anyway, they hate the car and the amount of money i spend on it. I also cant wait 28days for it to arrive from Japan via Nengun. As for the factory plate size, no idea, but i would say 9.5-10".
Chad, Didn't you have that made up by NPC?
Ever thought of getting a second hand twin plate from a wreckers? Ive seen a fair few coppermix clutches for sale at certain import wreckers yesterday. Providing they have plenty of meat left on them, they could be a cheaper option.
My 2c + Gst
I run an OS triple plate in my car - with a Nismo oversized slave cylinder it is really kind on the pedal feel, only slightly heavier than stock. My OS twin plate prior to this one was like driving a standard clutch albeit with a slightly harsher friction point. Driving in traffic with either of these clutches was fine, and they also hold after repeated 8500rpm+ launches :)
Alot of incorrect info flying around in here.
The whole idea of going for a twin plate is to avoid a heavy pedal....which is what a single with a thicker diaphram will give you.
I'm not even a fan of the singles with solid centres that are running buttons because they are very unforgiving on you and your driveline......these don't affect pedal pressure though.
Triple plate is a total waste of time for your car Abe.....not to mention that you will always be trying to release 3 plates before you can change years...not very good for lightening shifts.
Nismo have probably done more testing on GTR's than anyone else in the clutch department and have come up with 2 versions of the Twin Copper Mix one has a slightly heavier diaphram than the other, hence slightly heavier pedal but more clamping pressure.
I ran the lightest of the 2 Twin Copper Mix kits and found the pedal to be lighter than the factory single because they rely on surface area (being twice as much) and not clamping pressure which gives the heavy pedal. The use of organic material is for forgiveness on your driveline (ability to slip it in traffic) but with a mix of copper to increase grip and reduce fade on the track.
IMHO, either of the 2 Nismo twin setups give you flexibilty between street and track which would suit your specific requirements Abe.
Having said that, a car that's used mainly for track like Andrew's (Blue 32) would not benefit from this set up as he would want very little slip and lightening changes.....plus he doesn't idle in traffic so clamping pressue is not a problem in this instance.
Correct Pete! I had an os giken twin plate in mine (changed from an extreme 750kg pressure plate with organic clutch plate) and it was lighter and more driveable...Driven a nismo twin plate in a 33 gtst as well and it was much much better then his puck clutch he had in it before! I'd always go twin plate if i had my choice (and budget allows)
NPC make a great clutch abe i've run 2 group buys with Doug he is awesome to deal with
you can read a little info >>here<< and also see a few pictures
Thanks Steve, I am really considering a Jim Berry or a NPC clutch or if i really have too an Xtreme - As it is cheaper, and i have been hearing mixed responses about them.
Fitted my fmic intercooler piping kit. What a pain in the arse that was. :) Couldn't be arsed trimming the radiator fan, so I've removed it altogether for the moment. Does anyone recommend an electric fan kit?
I'll need to fit one before the track day.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
