  • Replies 14.2k
LOL at cutlery unification .... at the long-gone "Fairview Park Chinese" shop the old Chinese lady used to always ask when she presented your takeaway meal "You want spork"? And they were sporks too.
Me. I had Pete from PLMS do a quick road tune of my car once he installed the nistune daughterboard. Was good enough to drive home safely but he was quick to stress that a road tune is no substitute for a proper dyno tune
-D
actually a road tune with proper wide band sensor is better than a dyno tune but you have to be able to load the car up
Must be the day for old ladies to occupy all tellers at the bank :)
Another thing I hate ...
When you approach a red light, your lane is free, then a car from the other lane (with multiple cars) at the last minute moves across to get in front of you at the front of the lights. Then when the light goes green, they're the slowest car at the intersection. Why the f**k do they position themselves to pass the car in front of them, then proceed to not pass anything when they have a green light. ;)
And my vote also goes to the f**kwads who drive 60 in a 70 zone (or 50 in a 60), then just as you're about to pass them in another lane, they move over into your lane without indicating. :)
Happens on a daily basis Ruby. I had a moron flash his high beams and lean on the horn at me because I was doing 60 in a 60 zone and changed lanes in front of him while easily 2-3 car lengths in front of him. And he was in the right lane doing a max of 50.
Nearly every morning on the Port River Expressway there's someone doing 70-80 in the 90 zone and yes usually they're also in the right lane. Pretty sure a car got pulled over this afternoon doing about 60 in the 90 zone. Then there's those that change lanes without indicating, slow down at intersections (maybe waiting for a red light...?), those that speed up on yellow signals and run red lights, those that can't drive straight in their own lane and wander into both lanes, use the 3rd lane (the ones that merge into 2) at some intersections and then go slow enough to have to stop and allow traffic to their right pass..... and all because here in Adelaide there's too many fktards allowed on our roads. I could go on....
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
