  • Replies 14.2k
awesome. just spent 35 minutes on the phone to dtei. transferred to 4 different departments + sapol expiations processing, spent 20 minutes on hold, was told im basically f**ked in regards to my fine, and that they basically flip a f**king coin to determine if you get a warning or a (ridiculous) fine for having your feet on a seat.*
so basically, i lost $135 and 35 minutes of my life on a f**king coin flip.
sweet.
*as opposed to what i was told when my details were being taken, 1 warning, then a fine, recycling every 12 months.
Edited by scandyflick
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
