well, went test driving a couple of cars today for my mum, lookin to replace her mighty corolla. thought she was goin to be set on a Hyundai i30 CRDi, but it seems we found something more european second hand with minimal k's thats better quality
http://hamilton.deadline.net.au/aspx/searc...amp;loc_index=0
  • Replies 14.2k
at the moment, yes, but unofficially. theres still 90,000 odd votes to be counted. if theres enough liberal votes in that 90,000 odd for them to get another 2 seats, itll be a hung parliament.
I dont get how Labor can be celebrating so much.
They are now the most un-popular sitting parliament in history.
With the massive amounts of swing in the electorate, and they are raving on about how good they are..
Liberal even got more votes than them, according to the sunday mail!
Yes, if you look at the results, The Legislative Council vote results show that 292696 people voted for Liberal and 282663 voted for Labor. But Labor get the win as more people voted for them in the regional votes - more seats.
Speaking of politics, saw some guy on the side of the Southern Expressway this morning with a sign saying "Thank You" and waving to cars.
Looks like im gonna return the 2.5L swirl pot and go a bigger 5-6L swirl pot to be safe :blink:
So i dunno if someone wants to buy it off me or i can return it but its a 2.5L pederson swirl pot. Think it was $175 but i'll double check tomorrow if anyones keen :ninja:
so your buying genuine starcorps this time?
yes. yes i am.
thinking te37's or cr kais.
rota knock offs though, of course.
Am i a whore?
<snip>
I really need to sell a couple of sets.
i think you could be accused of being one, yeah.
Democracy is a myth. Don't believe the hype.
i dont.
So anyone been watching The Pacific? f**king awesome series!
nope. worth acquiring?
Edited by scandyflick
lol ok damo authorised romote access
wasnt anything fancy, just a home made reverse vnc single click utility designed to go thru my firewall and connect to vnc viewer in listen mode
pretty easy to make, and is only 150kb in size
-D
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
