  • Replies 14.2k
oil change tomorrow.. might head down to the drift later.. anyone going?
Not me. A handful of us will be at Old School New Age tomorrow.
Going to the Adelaide Gaol Tour tonight. Hope I get molested by a poltergeist! :thumbsup:
I might head out for a look, got coilovers in the ceffy now but dont want to take it out untill i shim the diff.
yeah heard this on the news this morning, if race car drives can't keep it on the track, how are we meant to when we don't even have that option? someone should mention this to mr rann... :)
Very nice efforts Luke,
I am defz hitting the casino with you next time I want to win some coin.
What will you be buying with the profits other then the swirl pot?
probably get all my nismo bushes I need for the rear end. Need another big win now to pay for all my ikeya formula stuff and all the speedflow/earls fittings.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
