i have no words to describe the stuff found in this thread...
http://forums.overclockers.com.au/showthread.php?t=860659
im not sure if i should laugh at the stupidity, or be appalled at the sheer amount of bigots....
the whole site is unbelievable
  • Replies 14.2k
Hey Chad,
what offsets are you running on your Stagea, and what size tyres. I'm putting on GTSt brakes and need some spacers so I may as well fill the guards out while i'm at it.
The rims I have at the moment are bogan/bob-jane spec +38 18x235s I'm thinking 25-30mm spacers front, maybe 15mm rear or just leave it as they are.
19x8 +30 on the front with 30mm spacers with 235 tyre and they rub on the guards so could do with a 25mm spacer instead. Rear are 19x9 +30 with 235's and they fit sweet.
what are your thoughts on these:
330mm with brackets,
Slotted & Ventilated
Dynamic Balanced
Heat Treated *Surface Coated
Heat resistance up to 900 degree.
$595 on trademe.
or here: http://www.conceptzperformance.com/Cart/de...29118.210.8.101
326mm with brackets, $430usd + postage
also arranging:
hks 87mm pistons & attkd h-beam conrods
acl race main & conrod bearings
ati 600hp harmonic balancer
rb26 clear cam timing cover
apexi multichecker
hks step-2 valve springs
hks oil pump
$3000 delivered. woot. double woot
I have been reading some of the Landover Baptist stuff Carl .... freaking hilarious ;) .... some of the appalled reactions to what is clearly a joke site are off the dial hilarious. Love this one in particular:
http://www.landoverbaptist.net/showthread.php?t=27676
try not to get cross drilled rotors Brendan they're more likely to crack
My GT-R rotors have tiny little hairline cracks 1 - 2mm long coming from the cross drilled holes,
very shortly I'll be looking for some slotted rotors, along with a brakefluid flush
Edited by Weezy
What happened to race car on a budget brandan? I mean its good if you can get these parts cheap but the costs are going to take you on a roller coaster and before you know it you've spent way more then you had intended lol
it has to be the biggest troll in the history of the internet. the size of the forum is amazing hey
yeh this is for down the track - auto awd rb26 stagea ;)
the sale of parts from the r32 sedan and my current engine will suffice
ie: rb25 ported head, tomei camshafts & valve springs - $2000
rb25 gt3076 garret ball bearing turbo - $1500
rb25 bottom complete bottom end with rwd gtr sump - $500,
rb30 manual box, tein r32 suspension, injectors, splitfires, - $2000
gtr fuel pump, stagea brakes, gtr front calipers, Panoz racing 4-pot billet calipers - $1000
gtst sedan shell, other bits etc, a few more grand easy.
fkn Chinese shit!
took the gate off this arvo, yep, was stuck open, taped it with a hammer, put it back together and back on,
started it up and woooot, i had boost again! gave it a good hard rev after it warmed up, and bah! prick of a thing stayed open.
ahh well, def in the market for a new gate soonish.
<3 the flutterz thru stainless intake pipe tho ;)
    • Or the brand new throwout may be unhappy...
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
