i have no words to describe the stuff found in this thread...
http://forums.overclockers.com.au/showthread.php?t=860659
im not sure if i should laugh at the stupidity, or be appalled at the sheer amount of bigots....
the whole site is unbelievable
  • Replies 14.2k
Hey Chad,
what offsets are you running on your Stagea, and what size tyres. I'm putting on GTSt brakes and need some spacers so I may as well fill the guards out while i'm at it.
The rims I have at the moment are bogan/bob-jane spec +38 18x235s I'm thinking 25-30mm spacers front, maybe 15mm rear or just leave it as they are.
19x8 +30 on the front with 30mm spacers with 235 tyre and they rub on the guards so could do with a 25mm spacer instead. Rear are 19x9 +30 with 235's and they fit sweet.
what are your thoughts on these:
330mm with brackets,
Slotted & Ventilated
Dynamic Balanced
Heat Treated *Surface Coated
Heat resistance up to 900 degree.
$595 on trademe.
or here: http://www.conceptzperformance.com/Cart/de...29118.210.8.101
326mm with brackets, $430usd + postage
also arranging:
hks 87mm pistons & attkd h-beam conrods
acl race main & conrod bearings
ati 600hp harmonic balancer
rb26 clear cam timing cover
apexi multichecker
hks step-2 valve springs
hks oil pump
$3000 delivered. woot. double woot
I have been reading some of the Landover Baptist stuff Carl .... freaking hilarious ;) .... some of the appalled reactions to what is clearly a joke site are off the dial hilarious. Love this one in particular:
http://www.landoverbaptist.net/showthread.php?t=27676
try not to get cross drilled rotors Brendan they're more likely to crack
My GT-R rotors have tiny little hairline cracks 1 - 2mm long coming from the cross drilled holes,
very shortly I'll be looking for some slotted rotors, along with a brakefluid flush
Edited by Weezy
What happened to race car on a budget brandan? I mean its good if you can get these parts cheap but the costs are going to take you on a roller coaster and before you know it you've spent way more then you had intended lol
it has to be the biggest troll in the history of the internet. the size of the forum is amazing hey
yeh this is for down the track - auto awd rb26 stagea ;)
the sale of parts from the r32 sedan and my current engine will suffice
ie: rb25 ported head, tomei camshafts & valve springs - $2000
rb25 gt3076 garret ball bearing turbo - $1500
rb25 bottom complete bottom end with rwd gtr sump - $500,
rb30 manual box, tein r32 suspension, injectors, splitfires, - $2000
gtr fuel pump, stagea brakes, gtr front calipers, Panoz racing 4-pot billet calipers - $1000
gtst sedan shell, other bits etc, a few more grand easy.
fkn Chinese shit!
took the gate off this arvo, yep, was stuck open, taped it with a hammer, put it back together and back on,
started it up and woooot, i had boost again! gave it a good hard rev after it warmed up, and bah! prick of a thing stayed open.
ahh well, def in the market for a new gate soonish.
<3 the flutterz thru stainless intake pipe tho ;)
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
