Adrian and I never received our stickers which I was under the impression came with SASAU membership??
I also have a bit of bacon to donate to the BBQ also. :D
nice i will cook up for brunch will go with eggs quiet well :P
  • Replies 14.2k
arrgh got another tune....no leaks found and car only makes 237.7rwkw......on 20psi (midrange) dropping to 14-15psi (top end).....time to get onto Hypergear as this turbo should be easily making around the 250-260rwkw mark.....
From what I've seen, Hypergear always inflates their power figures, that's just in my opinion though
ok so i have called the tuner AGAIA, and now he says that he didnt think i wanted to get the car tuned anywhere else but with him hence why he didnt put the nistune in..
is there more than one nistune? coz i asked for a nistune..
i didnt think there was more than one nistune..
any ideas what i can do..?
he is pretty much not doin ne thing to help except tell me i should have gone back to him..
the idea is that on occasions like this when i need a tune ASAP and the closest place is boost works then i go there...
Adrian, without knowing the exact circumstances of the original conversation it's pretty hard to comment.
But if in fact you made it clear that you wanted a Nistune and he understood exactly what you meant but failed to deliver, you have every right to a FULL refund under consumer law......regardless of how much work he actually did.
You are also not obliged to return to him so I can't understand why that flakey arguement is being used.
OCBA PH: 8204 9777 will tell you the same thing.
Well here I was on the way visiting a friend in seaford tonight when all of a sudden I see some headlights bouncy down a side street to my left. This car had easily been doing over 100, basically I had to swerve and put my foot down for him to miss me. He's come out of the side street and straight over the medium strip.
Shook me up for a good 30mins, as I could of easily been killed.
^^^^^^^ Thats really bad luke hope your ok
too kind ! :P
i know ill bring it to the track on monday, hopefully i come got Dr's for my wrist on the monday as well
This is sort of what i told Adrian, i also got emails from from 2 other Dyno places out lining the Nistune, what it is and how much it should cost so he can take them with him if he does the comsumer affairs thing
I'm going to jump on the anti hyper-gear bandwagon,
I wouldn't recommend them to anyone or use any of their gear personally.
From what I understand the customer service is great - untill you receive the item and then have issues with it and this is where the customer service falls apart
A friend of mine recently had a PU highflow done, the first time the dump flange looked very rushed and nasty, hypergear paid for return postage and made up a complete new exhaust housing/flange which has just arrived back in Adelaide this week, so would have to disagree with the poor after-sales support.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
