any of those kiwi's but the one on the left, ex lap dancer, bit fake and used up looking up close
prefer the blue in the middle, shame they speak funny, farsh and charps
tangles your not far from morphine ville,, the down south dump.druggies on every street corner. so sick of the crime in this town. lol
  • Replies 14.2k
lol. i think a 30det is a little out of reach for your average backyarder.
ok let me try again...
who can build a 30det cheap ? (if i provide head + block + pther little bits). Any idea how much a workshop wud charge to just put it together ?
lol
hi locky im kellie
ok boys i need some really good pointers for a job interview for tomorrow, it is going to be a behavioral interview
the job is for a insurance under writter
Try not to use the "F" word Kellie. I know its hard, but concentrate okay! :)
:D
Try to anticipate the type of questions they are likely to ask. Keep answers short and easy ... and relax. Good luck with the interview.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
