semi right Ben
If someone is standing over your bed at 3am and you put him out of his misery, you'd spend a couple of years in court and most likely get off in the end.
Different story if someone is in your shed or backyard though, then it's a case of the "equal or lesser force" rule applicable
Aye I know this, but if someones in my yard and they DONT run then the law be damned. Like you said a few weeks ago, nobody goes to jail in this state. Public opinion on this sort of matter is enough to sway any jury.
-D
  • Replies 14.2k
Yeah i always thought they were plastic till JIS told me they were fiberglass then i looked on the auctions and found they were correct
http://page2.auctions.yahoo.co.jp/jp/auction/b107935204
Only the lips are plastic im sure.
lol good luck with that whole not going to jail reasonable force argument Ben
i almost guarantee if you shiv someone who is stealing your car that wouldn't count as reasonable force hence you loose and we visit you in the big house
and if it really was a "shiv" that would show prior intent to do somebody harm and you may end up on murder but probably dropped to manslaughter with a good QC
we'd have to get permission from his new girlfriend first........Bubba!! ;)
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
