  • Replies 14.2k
They're that bad are they? I've heard good and bad about them, was thinking I'd try them out myself but seeing they're close, ah wells.
yes they are. Should of gone around the corner to Edwardstown custom body reapais or even more south to hounslow crash :ninja:
well your just silly then.
Why pay $30,000 for a parts kit that you can do in Australia for $50.
RIPS are pulling over 10,000 rpm on burn out and 1400HP on a standard RB30 block with standard crank and crank girdle.
Edited by D_Stirls
ugh. gtr purists. im siding with dale. f**k spending $30k on some liners and a bolt on deck when i can jump on the club and find a 30e bottom end for less than $50.
and ive heard of quite a few of the os kits failing at life. id be pretty torn up about $30k going to waste, but i wouldnt give 2 shits about a 50 buck bottom end.
*just had a look at the kaki kit, seems waaaaay too cheap.
makes the perfectly nice car look a little cheapish and nasty / track hack job imo.
and i could 'almost dig it'. the splits a little off. if it was something like this,
itd be rad, and i actually would dig it.
Think I should of called before I went for a drive, went all the way to MC Doyles Crash Repairs and they were closed... as in like they didnt pay their bills and got shut down. Guess I'll have to take my business elsewhere...
that really isnt a bad thing.
Edited by scandyflick
that Kaki* kit is only sleeves and a block deck so no $1500 is not that cheap
Dan its about 450-600 to get an AWD adapter plate for the RB30 but a deck is a stronger better RTA friendly option you keep your original engine number
No pos RB30 bottom ends should be in a GT-R imo
Dont get me wrong, I'm all for twin cam RB30's in VLT's, GTSTs, etc but not a GT-R... C'mon lol
Putting an rb26/30 in a gtr isnt a bad idea, if you use the car for performance or any kind of motorsport
keep the 26 stock tho if you want a streeter that'll hold its value - if I had two gtr's, I'd def put a 26/30 in the 2nd one
-D
This is actually a blessing for you. PM me if you want further info but I wouldn't send my worst enemy there...
And I'm a big GTR fan but nothing wrong with a 26/30. Shit, I'd build one would it be not for the legality issues and all. Don't fancy ripping out a motor to visit Regency
Word
-D
with all this talk of rb30's, im feeling good, just a cam, turbo..and a manual conversion away!
Also, whoever owns a 100 series Landcruiser...you sir or madam, know how to select a good car!
Definatly the best 4x4 ive driven, and the easiest to work on. :)
would it really be noticeable to the untrained eye though? (having a 26/30)
Easily. The RB30 block causes the head to be situated very high compared to the stock 26, pm cubes and ask him about how much clearance he actually has (he reckons its not a lot)... cant run a strut brace with a 26/30 unfortunately
-D
    • I've been sent a new main board to replace the suspected broken one. I haven't taken the screen out to look but I'm I'm assuming it's all plug and play.
    • Yes. It's not aesthetically pleasing. And most turbos sold these days are sold for aesthetic purposes (Insta likes/fame, etc). Also its cheaper to not machine it. The hot side is the pipe with hot air in it from the turbo to the intercooler. The cold side is the pipe with cooled air in it from the IC to the engine. Anywhere after the turbo will do. Certainly before the IC is better than the IC. But there is no massive imperative to get it from the turbo scroll itself, or from no more than an inch downstream. Those are nonsense thoughts. The only thing we want is a pretty honest measurement of the pressure at the turbo outlet, and anywhere from the compressor housing itself to the inlet of the IC will read approximately the same thing. Yeah, I disagree with Tao on that one. It's fine for an engine that only runs on the dyno at full throttle (or, equivalently, a drag car that only really runs at full throttle also). But some turbos that are particularly sensitive to overspeed (ie EFRs) would quite possibly get into a lot of trouble if run that way.
    • The sarcasm should have been easily visible. It was dripping off it.
    • Whether the brakes will clear the back of the spokes comes down to the specific wheel, as well as its dimensions (ie 18x8 or whatever else size). You can have 2 different wheels of the same size and one will clear and on the other the spoke design will not clear. So your question "Anyone riding around with 18 inch. that can confirm "that it'll fit"?" cannot be answered in a meaningful way. You need that person to be using the same wheel you want to use.
