  • Replies 14.2k
acts of kindness often go unnoticed in the world, especially on SAU. I want to give a massive thanks to SLEEPER85, aka Christian, who borrowed my coilpacks and dropped them off with a bottle of Johnny Walker black! Didn't expect to get anything and didnt ask, so if you ever lend or buy etc. something from him, hes definately a trustworthy forum user :)
Yeah. Few minutes per side for the castor easy and while you have the shock/spring out the camber arms right there.
just remember when you do install the adjustable items, to set them to the same length as the stock items. then you dont need to worry immediately about the alignment (ie it will be alright to drive to have a wheelie done on it)
I need some ideas for suspension/coilovers as my front castor rods need replacing (so I thought I might as well do the whole lot in one go). I have researched JIC FLT-FAS but from what I've heard, they're probably going to be too stiff for normal street driving and some hills work, especially with Adelaide's shocking road quality.
So what I wanted to know is what you guys use and what you'd recommend.
Also wouldn't mind knowing who/what workshops can install them for me.
theyre what... 8kg front 6kg rear? that isnt harsh norm. double digits is getting a bit painful. 8/6 is livable. my cusco's are 8/6, and theyre easily streetable. even with the dampers cranked up. whos told you theyre "probably" going to be too stiff?
from memory, luke (enr034) had 10kg springs on his cuscos, and that was beautiful to drive.
or... just double, triple, quadruple your budget and get pss9's or something similiar.
and just for fun, ask nightcrawler about his 'well thought out' suspension setup on the r34. that was f**king horrible if i may say so myself. bumpiest car ive ever been in.
as for installation... hardest part about fitting coils is setting the height. but thats more fiddling about than anything. actually fitting them though, im sure theres a lot of people on here that would be able to give you a hand. id do it, but you live on the other side of the world.
Edited by scandyflick
I'd have to disagree Dave....8/6 is beautiful......double digits no good for Adelaide.
A slight ripple on a bend with double digits and you come unstuck or a slight ripple at the end of a straight and your brakes lock up your wheels.
If worried about body roll, stiff shocks are not the answer.
Ive got 10f/8r. I was told to get this by Ryan because the Skyline is heavier than a Silvia, 180 etc.
On the topic of suspension, I had a hideous knocking sound in the front left, pulled it apart today and found the upper arm bushes need replacing. Recommendations/experiences on what bushes to use?
Saw that with general searching and creating a topic:
http://www.skylinesaustralia.com/forums/in...t&p=5186278
Although he did say that it's only not so great if it's a daily driver, which in my case it is not.
Probably won't fit the coilovers for a bit now (might still buy them as they're on special), but at least going to do the front castor rods ASAP. I'll speak to you about it on Wednesday week.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
