  • Replies 14.2k
want to paint them up as bright as that (with the valley cover and cam gear cover in black)
i dont feel confident doing them myself, happy to chuck you some cash to do it though :)
AAA powder coaters at Lonsdale, it will look 11ty billion times better than a spray can and be much more scratch resistant, and they will blast them first so it will come up mint. :)
I suspect broke a good behavior driving clause, sorry to hear but boys will be boys time to take the R off the road and make it better :ermm: or kill your liver :P
Your on the money there Madaz, Had already appealed my license back in 2007 - I was so close to getting off my P's too.
I'm thinking a combo of pwnting my liver and give the R some $$ love lol.
Biggest pain of the whole situation is bus/train to work everyday for the next 12 months lol
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
