  • Replies 14.2k
turns out 'collingrove hill climb' is sccsa speak for 'shit value for money'.
$90 for 4 runs up the hill.
i got a 5th because i told a little white lie to the official.
i dont think ill bother with collingrove again.
Edited by scandyflick
good thing i couldnt go then.....that is really bad value for money....i would rather do another sausa track day $265 you get awesome track time and enough cooling down time....loved it
would a decent sized motorcycle battery be enough to start an RB20?
struggling to find a car battery smal enough to fit in tray with cooler piping.
thoughts?
maybe something like this would fire it up but cranking amps aren't always the be all and end all, a battery needs to sustain the vehicle's amperage, depends on the current draw of an RB20......wouldn't bother ever using lights again I would imagine.
Non lead acid battery in boot is the way to go.
http://cgi.ebay.com.au/12V-AGM-DRY-FIT-HAR...=item4ceeee81f8
i enjoyed it purely because it was a chance for me to give the 200 a bit of a belting.
that being said, as far as i care, that $90 couldve been better spent on a 4 minute lap dance and a cold beer.
funny, a "full day" of motorsports, and i used more fuel idling in the paddock than i did on the course itself. pathetic.
thats pretty much where i put mine craig
bolted box thru floor, never got in the way. was then easier to chuck the isolator in it too. im not a fan of boot mounting batteries in 31s, especially with the fuel tank being in there. i know in other cars they do it, but theres nowhere good (aside from the spare wheel tub) to put it where you can bolt it down
Did they inform you of the likely number of runs you'd get for the day? I would have thought they'd give you some idea how many runs you'd get (like track days). I know the competitors who paid something like $190 on Saturday only got 6 runs.
I'm guessing too that the $90 included the $25 day licence?
Saturday was funny. Some guy in a 180B did his burnout at the warm up area in preparation for his first timed run, and all I smelt was clutch. Poor guy couldn't get up the first section to the first turn. Rolled down the high backwards and failed trying again. Surely, he must have known his clutch was gone before he entered on the day. And he blew $190 odd. At least you made it up the hill to the finish line 5 times for $90. :P
how much to get it rewired matty???
i kinda need it donr before may 8th lol
motorbike battery was a short term solution till i mount it in back seat
contact Bit Sus (Nigel) and see if he can do it for ya
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
