Just got back from Melbourne. Left Adelaide at 4:10Pm yesturday arrived in melb at 5:30ish melb time. Picked up a 280rwkw supra with a mate and drove it back.
First road trip. Wasn't to bad :happy:
I like the trip between Adelaide/Melbourne - its not too long.
It was epicly fun driving back in the GTR... and kind of not at the same time(stiff suspension and loud exhaust with windows down made the right ear feel a bit funny after awhile), and surprising not too bad on the wallet - less than 2 tanks of fuel.
  • Replies 14.2k
i did adelaide to canbera in a stiff as coilover swift with no a/c in 40 degree heat. we were both burnt like lobsters on arrival. went through about 10 litres of water each.
but you gota look at it as an advernture :happy: and country people are funny when they see a modded car
Edited by Inline 6
On the weekend I drove to and from bendigo, VIC in an R33 with coilovers and 300~rwkw and only wet through roughly 4 tanks of fuel including driving around bendigo and heathcote,
I wasn't a problem at all.
SOO my horns dont work now
press the horn button and all i get is clicking in the engine bay from the relay
ive replaced all the fuses to no success
so this would indicate that the horn has been shorted out
correct me!
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
